B A C N O W
Bryan
SoCal
Nissan Titan Pro4x
FWIW, I did the 1st clip position (lowest) on both front and rear, came out with approx. 2” lift (after settling). Bronco is level now and I l8ke the fact that if I add more weight at either end I can adjust.
And the ride/handling is sooo much better than the stock Hibachis…
Did you readjust your clip position settings? Earlier, you posted something different:
”I used clip setting #1 in rear and #2 in front which gave me approx. 1.75” lift in rear and 2.2”lift in front. Front has since settled to approx 2”lift. Keep in mind I’m lifting a non-SAS OBX and had the complete Bilstein 6112 coilover units installed (including Bilstein springs).”
HotLap
HotLap
Bradley
CA Central Coast
2018 Ford Raptor and 2019 Yamaha XSR900
You are correct sir, I actually deleted this entire response, (your above quote), but for some reason it still posted? Please disregard as my original posted info is correct👍
Update: was able to go back and delete erroneous info post, thanks for bringing my attention to it and good luck with your Bilstein 6112s, fantastic upgrade!
Thr33Thr33
Jesse
Fresno Ca
2021 Black Diamond
Mine is getting installed today along with new 35's and I cant wait!!!
GroovyGeek
Boyan
'23 Bronco BD
Thr33Thr33
Jesse
Fresno Ca
2021 Black Diamond
I got mine installed and upgraded to some 35's on Method 705's. Did clip 4 in front and 3 in rear to get rid of the factory rake. Also did some Camburg UCA's. What a massive difference in ride quality. So much nicer to drive!
Ford Bronco Bilstein 6112 suspension kit installed…WOW!  HUGE improvement over stock OBX Hitachi coilovers 20231217_132835
Rferrara
new york- long island
tesla
for those who had SAS and upgraded to these.... Im getting mixed reviews on Plush vs. Firm. if your doing mostly freeway driving and normal traffic around town (normal life) do these provide a comfortable/plush ride or do you still feel the road vibration the same?
if so any recommendations on coil over systems for ride comfort on pavement?
thx
5GENIDN
Joe
Idaho
thx
You are asking for a subjective opinion.... like how soft is that couch?.... You really need to ride in one that has this set up.... Exact same vehicle, one person will describe as firm and the next will describe as plush.... Only you can determine if it is what you want. Someone in New York has this set up... I would bet on it. and since most of us are really proud to show off our mods, my guess is you should be able to find someone that would be more than glad to provide you with a ride along... Contact your local club... Someone will know someone....
HotLap
HotLap
Bradley
CA Central Coast
FWIW, I upgraded from a non-SAS Hibachi suspension. So I went with Bilstein 6112s (wanted to upgrade from the soft Hibachi springs). In my case the improvement was amazing, seriously reduced brake dive and suspension “wallow”…definitely a firmer, more controlled - but not harsh ride. Good luck!
Beach_Bum
Ken
St. Augustine, FL
Lil Mul
2023 2DR Badlands SAS / 2016 Mustang GT PP
thx
They ride the exact same as the yellow SAS shocks with noticeably less body roll and nose dive. They are still on the firm/stiff side ... as any "digressive shock" will be. If you want "plush" look into some Fox shocks
GroovyGeek
Boyan
'23 Bronco BD
Been using the Bronco on tons of trails in AZ and UT for the past 2-3 days. Loving the 6112s so far. Perhaps the most noticeable difference for me till now is how they handle washboarded roads. Just step on the gas pedal and feel nothing.
JuBi3
Louisiana
Pics of my horsey before and after 6112s. Lift is 2.1" in front and 2.4" in back. Incoming rake was 10mm. I like the outcome. Reasonable lift without the wheel wells looking ridiculously empty. Used the opportunity to install the RC rack and pinion bushings and the trac bar relo bracket.
For the avoidance of doubt, work was done professionally, I would never dream of doing something like this on my own. I loaned the truck to Bilstein for a week to test fit some new gear, and they have been supremely professional throughout the entire process.
do you have 33's or 35's in this picture?
GroovyGeek
Boyan
'23 Bronco BD
