Best Practice 5 Tire Rotation?
Skmac
Subaru Outback, Jaguar F-TYPE
Way to verify that they did/did not do the work: $5 tire crayon at AutoZone. Mark the inside of each tire 1-5. Make a note of it before you drop it off.
Thats a great idea
Rednek
Jimmy
Northern Alberta
Just a word of warning to those that live in a area with mandatory inspections,you may get a fail on your tires at year 5.
Cookieck
Georgia, USA
Camaro SS, Indian Chief Vintage, Yamaha Fz1, Honda Shadow, etc
All this heated discussion bout tire rotation and including a spare and here I am not used to rotating tires pretty much at all anymore since I kinda can’t on most my vehicles, cause 4 motorcycles and a vehicle with different width wheels front/rear and no spare. technically side to side rotation is possible as tires are asymmetrical but not directional, but I do plan to change the staggered wheels/tires to a squared setup once these wear out so didn’t see much point in side to side swapping. Still won’t have a spare to carry as a full size tire won’t even fit in the “tire” well, but could rotate 4 tires at that point.
Gotta say though, love it when I see wranglers with huge tires still carrying the stock tire size spare on the back. I’m sure there will be a new bronco sporting that look at some point.
dcg2
dcg2
Don
PA
Honda CR-V
Razorback
Dallas
Lincoln MKX
This thread is hotter than BL vs Sasq suspension...
Ford Bronco Best Practice 5 Tire Rotation? ZomboMeme 31032021054251
Rednek
Jimmy
Northern Alberta
Panaran
US
CX5
The correct answer is G. Less complicated than F.
And YES YES YES, you do need to rotate that 5th tire, your tires will last 20% longer that way. Do the math.
Some of us (OBX) are trying to wear out the tires as quick as possible to justify new ones :)
Pancho Kornwallace
Pancho
Mustang
I have decided that I cannot convince you to rotate your spare tire in.
You are going to overpay for your second set of tires and you are going to do that change earlier than you should, but it its not my money and hopefully it will keep the nice people at Discount Tire employed.
Carry on...
SevoSandman
Perry
NorCal
Toyota 4Runner, Porsche Cayenne GTS
HoosierDaddy
__ Eric
so when it’s time to replace tires, now you have to replace 5 instead of just 4 since you put the spare in rotation...
IE...it costs 20% more.
Lol
HoosierDaddy
__ Eric
How should I rotate my directionals?
Should I carry two , side specific, spares?
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Carry on...
See...that’s the difference
1) I’m not trying to convince anyone to do 4 tire vs 5 just giving you 5 tire people a different perspective
2) your math will never add up....if we both replace 5 tires at some point, why would mine cost more because i didn’t rotate 1?
3) another math...tread wear will never be even on 5 tire rotation...even your first rotation, you will automatically have 1 different than the 3 on the ground. On your 5 rotation, i will give you a slim “Maybe” They’ll be even but that’s only if you drive the same roads every single day and rotate exactly at the same mileage every single time. Not sure about you, but i like to go to random places every now and then and definitely will not be pulling over just to rotate at the exact mileage just to say i got 20% more out of my tires..
4) lastly....i will not put a used ugly tire on the back for all to see on a beautiful vehicle like a bronco...
Enjoy your travels and stop worrying about the extra 20% you’re trying to squeeze out of it.
username1
CA
I think they were referring to the cost of traveling x miles, not net $ spend. The dollar spend is neutral but rotating 5 is more efficient. Rotating 5 you will travel more miles for the same $ resulting in a lower $/mile avg.
Very passionate discussion in here and I can see the reasons for choosing both but I like the tradeoffs rotating 5.
Gamecock
You're fine doing 4 if you KNOW you won't be changing tires when you buy new ones...I would never want to be locked into that. You also have to keep that back tire lubed up all the time, and since it is not rotated, it will look like crap anyway most likely, especially sinc you are only going to buy 4 apparently when you buy new tires. So, to avoid basically no extra cost or real labor difference you: 1) Have to buy new tires in more frequent intervals 2) You lose flexibility in being able to change to another brand or size tire (without also changing and wasting an unused tire). So two cons, no real pros to only rotating 4.....and that treadwear thing you are claiming just doesn't hold water. It all evens out and you won't be able to tell the difference in the tread once they've all taken a turn on the back...from someone who has always rotated 5 when I had a tire exposed on the back.
