- First Name
- Jared
- Joined
- Feb 20, 2023
- Threads
- 45
- Messages
- 7,118
- Reaction score
- 13,878
- Location
- Denton, TX
- Vehicle(s)
- 2023 2dr Badsquatch
- Your Bronco Model
- Badlands
They can leak but mostly from where the raise/lower valve hasn't been tightened back down(closed) after use. My old '91 Ranger came with one stock mounted lying down behind the seat and still is fine today.
Haven't seen it yet.New Reacher is the best
You are correct. It's been quite a while since I've had to use it but that does jog the old memoryThat wasn't a real bottle jack. It had a screw mechanism and was not filled with fluid.
Actually that reminds me there is a jack that a lot of people used to look for for this same reason, it's very similar to the jack that came in the Rangers but it's from older Toyotas and lifts I think like twice as high. Apparently not all of them came with them, you had to look for one that had like Japanese writing or something on it I can't remember.That wasn't a real bottle jack. It had a screw mechanism and was not filled with fluid.
This is why you get a mechanical screw Toyota SR5 bottle jack. It fits under the rear storage too. I actually put a DV8 box in to add additional space, I can fit all my recovery stuff in there now.I don't think any of the bottle jacks are suppose to be stored laying on the there side, they can leak and you have to air purge after standing up right.
Pic?This is why you get a mechanical screw Toyota SR5 bottle jack. It fits under the rear storage too. I actually put a DV8 box in to add additional space, I can fit all my recovery stuff in there now.
ThreadPic?
I’d love to see a better organized space below that deck keeping some minimal recovery gear there full time.
Hi-lift jacks are rather notorious for breaking people's jaws, which is why people done recommend them much. If you use it properly to a tee, then you'll most likely be fine though. Keep your body out of the way of where the jack handle could go if it rebounds.Wonder why no one recommends the Hi-Lift jack. For the money it's essentially the same physics of the ARB one, just not hydraulic. Thoughts?
Hi-lift requires appropriate heavy bumpers or side rails which are not typical anymore.Wonder why no one recommends the Hi-Lift jack. For the money it's essentially the same physics of the ARB one, just not hydraulic. Thoughts?
NICE! is this it?I keep a Vevor Air Jack in my rig. Since I have onboard air, it’s fast and safe. (Knocking on wood) I have never needed a jack while out on the trails.
Yessir - the model I purchased has a little different handle configuration. The style you linked will require some long arms to position it under the vehicle easily (but same lifting mechanism).NICE! is this it?
https://a.co/d/739Ql79
