Best Jack?
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
They can leak but mostly from where the raise/lower valve hasn't been tightened back down(closed) after use. My old '91 Ranger came with one stock mounted lying down behind the seat and still is fine today.
That wasn't a real bottle jack. It had a screw mechanism and was not filled with fluid.
Ford Bronco Best Jack? Screenshot 2025-05-06 152747
Rydfree
Benny
Alabama
You are correct. It's been quite a while since I've had to use it but that does jog the old memory :)
GI_Jo_Nathan
Jonathan
Actually that reminds me there is a jack that a lot of people used to look for for this same reason, it's very similar to the jack that came in the Rangers but it's from older Toyotas and lifts I think like twice as high. Apparently not all of them came with them, you had to look for one that had like Japanese writing or something on it I can't remember.
I was going to try to get one to replace my broken scissor jack with. But looking on eBay they're kind of pricey and you can't really guarantee that you're going to get the right one.
Ford Bronco Best Jack? Screenshot_20250507_080628_Chrom
vrtical
Doug AI
GSMNP, TN
Fords
I don't think any of the bottle jacks are suppose to be stored laying on the there side, they can leak and you have to air purge after standing up right.
This is why you get a mechanical screw Toyota SR5 bottle jack. It fits under the rear storage too. I actually put a DV8 box in to add additional space, I can fit all my recovery stuff in there now.
Mdozier
Nashville
95 F250, 24 Badlands
Pic?
I’d love to see a better organized space below that deck keeping some minimal recovery gear there full time.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Due to noise, weight, and size of footprint reasons, I can not recommend the Badlands/Pro Eagle-copy jack inside the vehicle. I just got tired of the lost space and constant rattling over every bump. I finally removed it and haven't looked back. I'll probably throw in a Toyota screw jack that I see others mentioned earlier because I've got a few of those laying around.
Ford Bronco Best Jack? 6zXHviu
Ford Bronco Best Jack? 4Pbm3v6
davids240
davids240
Phoenix
2024 Bronco Raptor
Wonder why no one recommends the Hi-Lift jack. For the money it's essentially the same physics of the ARB one, just not hydraulic. Thoughts?
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Hi-lift jacks are rather notorious for breaking people's jaws, which is why people done recommend them much. If you use it properly to a tee, then you'll most likely be fine though. Keep your body out of the way of where the jack handle could go if it rebounds.
EveryDayBronco
Motorcycle
Hi-lift requires appropriate heavy bumpers or side rails which are not typical anymore.
It also takes up a lot of space. I have one I bought new 15 years ago in my garage - have never justified using it for anything vehicle related.
The OEM jack plus the OEM sasquatch jack spacer can lift my 32" wheels just enough so if you have larger diameter tires, you'll need few 2x4 blocks to put under the jack.
For 40" tires - you're going to have to get creative!
I have a Toyota bottle jack that I welded up a few different extenders/adapters for so I can safely lift round rear axles or other odd spots. I believe there are custom jacks that have extenders and attachments -you'll have to search for them!
Gene Dios
Atlanta
I haven't had any issues storing my safe jack bottle jack sideways. Just needs to lay 'up' with the port in the upward direction. Used many times and it's been stored that way for 3+ years
Bschurr
NY
