Base Model Question
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Still waiting for a Base, 4 door, Stick, Bronco I ordered on 7-11-26. This will be my daily driver and ordered the Base to save money and have less tire noise. Many threads speak of the upgraded platforms so my question is how does the base preform in moderate off road trails and over half a foot of snow?
A lot of this is subjective (what do you consider "moderate" trails? Is there any slope under this 6+" of snow? etc..), but a base Bronco is already way more capable than most 4x4's. I suspect you will be just fine, and might start mod'ing simply for want rather than need.... 🤠
KABQ
Aaron
Albuquerque, NM
Honestly it will be way more capable than you think. Take it out and find out for yourself when you get it, I think you'll be pleasantly surprised.
HalfmuleFarmer
Thomas
2025 Badlands
Concur. Driving in deep-ish snow is more about tires and not being an idiot than it is any specific higher end vehicle feature. A great snow-performance tire (like the Nokian Outpost) might be all you need to consider. The 7MT will likely get you around on ‘moderate’ trails just fine (which I’d define as anything short of true rock-crawling or mud holes).
WXman
Central Kentucky
2024 Ram 2500 Cummins, 2025 Jeep Wrangler Unlimited Rubicon
All it'll need is a very small lift and a good set of 35" tires and you'll go anywhere you want to go. If I had a build like that coming, I'd run a 35x11.50 and keep the stock wheels to save money.
Pbethel
Patrick
Kingman AZ
2025 Bronco Sasquatch, 2016 Transit 250 148 MR EB
I traded up from a 2021 Ranger with 255/65 R 17.The Base comes with 255/70 R 16.
The base tires are 30" compared to the Rangers 29" and I found the Ranger XLT Sport 4x4 more than capable for mild off roading. The Ranger did have a rear locker that I rarely used.
Compared to the Bronco Base with Sasquatch....it might as well have been an Escape.
Sasquatch is a significant off-road oriented upgrade for all but the Badlands/older Black Diamond models
(All older Wildtraks and Heritage models are SAS models, so kinda ignoring those here)
You get the 4A Transfer case, front ~and~ rear lockers, the bigger m210 front axle, deeper 4.70 gearing, the Bilstein HOSS 2 suspension, the HOSS 3 steering rack, and the most obvious 35" tires with less offset wheels and pokier fender flares. That's for all trim levels, Base up through Badlands (which already has most of this at that Trim level)
For just doing moderate trails - SAS definitely is ~not~ needed. I use OnX, using their ratings, up through Level 5 no problem, most Level 6's will be achievable with experience. 7 really starts to push it and you will probably start wishing you had some of that SAS stuff by here, but many would probably be ok if you are careful and have some experience under your belt.
It's value at purchase is ... debatable, especially on the various trim levels and as the cost of it has went up over time. It probably will translate to much better resale value though.
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
I think it really depends on how you define moderate.
The base Bronco comes with open diffs and 30s. People used to do the Rubicon with open diffs and 30s. base Bronco should go a lot of places, the question is how hard you're willing to work and how much damage you're willing to accept.
23OBX2.7
AB Canada
2023 Bronco
They just about give away BB/OBX take offs. A 4-door with 30's make it look like you skipped leg days.
OBX takeoffs look amazing with 275 or 285-70-18s with decent side lugs.....totally transforms look of wheel to a high end machine face wheel thats looks poor with 255-65-18 tires
Stromski
Walter
Annandale Virginia
2025 Bronco 2 door
I bought a base 2 door MT in February.
I have only had it in a few inches of snow, but that was going to my country house which is about 3/4 mile from pavement and one very steep hill. No problem.
I brought it to my overachieving brother's MOUNTAIN house which is 4 miles from pavement. He calls the access a road, but nobody else would. Hey, it is his land and he can call it what he wants. 4H, 1st gear the whole way. It was dry, no mud involved.
I never got the all season tires near the edge of their abilities. I changed to 33 inch Cooper Discoveries mainly because the "little" wheels (they are actually quite big) seemed out of proportion to the look of the truck. The Coopers are a civilized road tire. The size removed the crisp steering input. The diameter changed the gearing. It runs one gear higher than it had before.
I do not think that the tire change was a mistake. I think the stance is great. The maximum Ford available tire size without a lift makes it almost look lowered. The floaty ride is fun.
I kept the steel wheels with the 30 inch road tires. One day, I might put them back on and drive a GO-KART for a while!
kimmiemom64
Greenville, NY
2022 Ford Bronco
I have a 2022 Base with 80k miles on it. Live in the woods of upstate NY and have never had an issue in snow. I sometimes have to wait more than a day for my road to be plowed, and have not gotten it stuck yet. I wore out the factory tires ('cause I'm cheap) and had no issues with them. I did upgrade the tires to a bigger, more aggressive Cooper tire and while they are a little bit noisier, it's really only noticeable on the highway. Probably going to go a little less aggressive tread on the next set since this is just a daily driver and I rarely go off road (although some of our roads are like being off road!) Good luck with your Bronco - I love mine!
Owl
G
Sacramento
White Wrangler JK, White Bronco Base 2Dr
I upgraded tires and wheels immediately, right here on this forums marketplace I bought some Badlands wheels and K02s. During the winter I install actual winter tires.
How do you like the KO2s & Badlands rims? I was thinking of upgrading my Base 2Dr/V6 which currently has standard OBX/18 takeoffs?
Have to do any messing around with the suspension?
Just an FYI to original poster... I didn't notice any noise difference between the Base & OBX tire noise.
Thanks!
