Base Model or Big Bend?
AZHUND
2020 RAM 1500 5.7L 4x4, 2018 Wrangler S 3.6L
I thought I saw somewhere that upgrading to 33's on Base or Big Bend some gearing has to be changed as well, is that true?
Not "needed" but helps when you go up a tire size. Other thing is your speedometer will also be off slightly. So will need to do some mental math each time you check your speed unless you get that adjusted.
Fuzion2Bronco
Asher
New England
Base Sasquatch
Depends on what you mean by 'gearing HAS to be changed'. Because technically, it doesn't have to be changed, but it will help turn the tires a little easier. Plus the lower gears will help me with towing. So the 3.73's (stock) will still tow, but 4.10's would be a little better and so on.
So, not necessarily a requirement, but a bonus to have the lower gears. My wife's Jeep has 342's I believe. And it doesn't tow for shit. I think he old Jeep had 3.73's and did tow much better. Both Jeeps ran 33's, and the newer one with the higher gears seems a little slower as well. But of course this is a Jeep, so take it for what it's worth.
I am not planning to do any sort of Towing on the Bronco, I have a Pilot if I have to do any towing, if not I will just rent a U-Haul.
Good to know that I don't have to spend any extra Monies to any other mechanical changes. I would be Happy with Base with 33's.
Edelfin
Emmanuel
TEXAS
For me, I pretty sure at least, the Base 4 Door is the best value. I need the 4 doors and auto. More so if the options list lets us do a lot of a la cart stuff on the Base. The only thing I know for sure, right now, is Base 4 Door + 2.7 + Aux Switches. Hoping I can add a rear LSD (more useful for me) or at least bump gearing to 4.27. I'll do the E-Locker if that is the only choice to get the gearing. Otherwise, I'll just run open diffs. Also hoping for a tire/wheel change to 235/85R16 or 255/75R17. Black steelies would be fine, otherwise something in a 5 or 6 spoke type design in black. I won't be able to do the color I want (CG), but I'm okay with Carbonized Gray or Iconic Silver, maybe Velocity Blue. I think those would go best with blackish (CG, I think) trim.
100% agree. The 4-DR BASE with auto standard is a huge value. Even if you get top of the line aftermarket tires you'll have savings. Add individual features from Mid-Package and higher trims and it is THE trim to get.
Edelfin
Emmanuel
TEXAS
I'm having a hard time finding which colors are available with which trim. But I see a lot of people saying Velocity Blue. Is that even an option for a base? Or is that like Race Red and requires higher trim?
On Ford's site with the colorizer, the Antimatter Blue looks nice. But in every pic we've seen (either the bronco painted pics, or the color samples) it looks too black for me. Velocity would be nice, I just didn't think it'd be on a Base.
Time to go use the search feature again :rolleyes:
VELOCITY BLUE should be available on the BASE and we learned there is no delay on when it'll be delivered. Which is amazing!
Ford Bronco Base Model or Big Bend? Screen Shot 2020-09-11 at 10.02.20 AM
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
I think the gearing change would be more important on the 2.3 with auto for tire size increase. The manual has like a 4.46 final drive ratio and the 2.7 has the added torque.
If I do the 2.7, I'd still like to change the gearing, but not a deal breaker. If I keep the 2.3, I need the change since I'm going auto. This is the reason I keep looking at the BB, plus the access to Cactus Gray!!
My only real issue with the Base.....the tire size. I know it doesn't sound like a lot, but couldn't Ford at least start at 265/75R16?
EvlNvrDys
Hunterdon County, NJ
Thank you for that. I couldn't find this chart on Ford.com and trying to come up with the correct search term over here I was getting nothing.
This makes my decision a little easier to go back to my original build: 4 Door (Base) + Squatch + V6 + Hard Top in Velocity Blue.
Now if only someone could work their magic and get me Race Red I'd be in heaven! My '12 Mustang V6 BASE came in Race Red... All trim levels should have that color! :mad:
Edit: Now I gotta go find the posts with the Bronco's rendered in Velocity Blue, always something ha ha.
And lastly, I think those are the 2 things that have people on the fence between Base & Big Bend.... Tire Size & Color. Otherwise Big Bend wouldn't even be needed here.
Edit #2: Found it... I think I could rock this...
Ford Bronco Base Model or Big Bend? 2021 Ford Bronco Sasquatch Velocity-BlueBronco6G.com
Though I'd still prefer this....
Ford Bronco Base Model or Big Bend? 2021 Ford Bronco Sasquatch Race-RedBronco6G.com
BaseMod
East Tennessee
Frontier 4x4
The 265/75R16 is probably what I’ll slap onto the base rims. I run that same size tire on my Frontier.
Fuzion2Bronco
Asher
New England
Base Sasquatch
I went from base to BB and in last few days back to base. OJ white or CG...
Are they All Season or All Terrain? I found All Season which looks like All Terrain in Walmart for $74.00
Ford Bronco Base Model or Big Bend? 1599837841090
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
The longer I wait on the B&P, the longer I can't make up my mind here. And the line I made 'bold' in the quote does ring true in so many ways. The one reason I consider the Big Bend is because I WANT 'Race Red'. I'm trying to convince myself that AB will work, but it's too black for me.
Basically, my ideal build would be: 4 Door Base (comes with Auto) + v6 + Squatch + Hard Top. The only 2 things I'm missing are auto start and a color that I would actually like!
My optional build is: 2 Door Big Bend (comes with hard top) + v6 + Auto + Tow in Race Red. Upon delivery take to a shop and slap something like Nitto Ridge Grappler 285's (33's) on there, for about $1,000. The one thing I'm missing here is the space of the 4 door.
Optional build #2: 2 Door Black Diamond (comes with hard top) + v6 + Auto + Tow in Race Red. Only benefit to ME in this one over the BB is the washout interior & rear locker. I don't need the bash plates or rock rails. My Bronco won't ever be rock crawling, maybe play a little in the mud at most.
I find this is going to be a difficult decision for me to build either way. I'm looking to stay closer to $40k or less, because I drive a lot of miles and don't want to be spending more then that. Obviously that number will be close to $40k, maybe a little higher, maybe a little less, that's just my target point.
So I probably brought nothing to the discussion here, just stating what I'm looking at.
My preferred build was the Black Diamond, mainly for the rear locker and Cyber Orange availability. I had never considered the Big Bend until I found out you can get it with the rear locker (probable cost ~$500). So, 4dr Big Bend, 2.7L, hardtop, rear locker in Cactus Grey saves me $2500-ish relative to the Black Diamond. I don't need metal bumpers, rails, etc. rubber floor is nice, but really who cares. Cloth makes me sweat a lot less than vinyl too. Tires are a bit taller than the BD too which I can upsize when the stocks wear out. Also, I prefer BB aluminum to BD steel rims & hoping they weigh a bit less too.
I was all over Squatch until I realized it was mostly because of looks and ride height for me. I won't go offroad too much and Squatch wheels will be a bear on the highway.
Fuzion2Bronco
Asher
New England
Base Sasquatch
I run A/Ts. Looks like a great price on those Coopers
A/Ts are a Pricey and the BFG is the Best Seller for Off-Road Community
Ford Bronco Base Model or Big Bend? 1599839391766
EvlNvrDys
I just put a set of Nitto Ridge Grapplers (285/70/r17) on the wife's Jeep last winter. So far she likes them. Depending whether or not on sale, run in the $180-$220 range for that size (the wider 33's) and they look good. So far handle good as well, they are more of a hybrid between AT & MT. I'd probably run them or some BFG's MT's or AT's. A lot of people also mention the Faulken Wildpeaks.
Ford Bronco Base Model or Big Bend? 1599840234613
Hoofnmouth
mark
N ca
ford focus st
Same here was set on cg then the white now the whole world is falling out of the sky due to fires so im back to cg
