Base Model Question
Stephen Spataro
NY
1968 Firebird convertible, 1974 Triumph TR6, 2019 Corvette 7 speed manual
Still waiting for a Base, 4 door, Stick, Bronco I ordered on 7-11-26. This will be my daily driver and ordered the Base to save money and have less tire noise. Many threads speak of the upgraded platforms so my question is how does the base preform in moderate off road trails and over half a foot of snow?
Thor_1
2026 Bronco Heritage
I have a heritage model which has the 35s and there is little road noise. You should get what you want since tires are an easy change. I would recommend getting the Sasquatch package or a Badlands for the 4A and locking diffs.
Techun
Pa
BD, 2.7, MIC, 4dr
You'll want maybe 33" tires right off the jump
HalfmuleFarmer
Thomas
2025 Badlands
His order is already in.
OP: You should be fine. Maybe a change of tire for noise and/or winter performance, but you can wait and see. Enjoy it!
CalvinT
Calvin
Phoenix, AZ
I think any below the Badlands will have pretty low tire noise. Just be sure to order an option package that includes sound deadening.
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
I can speak for the big bend: It has almost no tire noise. I've not done any difficult trails to have an opinion, but even on the stock duelers by big bend has done fine on the service roads I've taken it on. I've been ok in the snow I have done, but nothing abnormal. I dont think that would qualify.
While I'd prefer a better offorad tire, if tire noise is a factor, you should be able to get big bend takeoffs super cheap which will put you on a 32 right away.
All Broncos have 4Hi/4Lo
You’re only limit off road will be your clearance really - Base has smaller tires (~30”) on smaller (16”) rims. Big enough to run moderate trails for sure
Snow will be largely up to your skill - you will provably want chains, and proper snow tires make a huge difference. 4A would be the only thing you are missing from a higher trim but that’s hardly essential - more a convenience thing.
From where I started - the only difference in my Big Bend and a Base were
- Factory Fog lights
- Leather wrapped steering
- White Bronco letters on gray grille
- 17” rims
Jakob1972
Everglades
Steven
Spring Branch, TX
2025 Trax 2RS, 2022 Camaro, 2022 Silverado, 2004 Fummins F250, 2008 Chevy Cobalt
Everglades
Yup just a better tire for snow will make a big difference and depending on the tire be a great tire for off-roading. I just put a set of Falken Rubitreks on my truck and am super happy with them. They are 3 peaks rated AT tire.
Ford Bronco Base Model Question IMG_4158
23OBX2.7
AB Canada
2023 Bronco
base will work fine cheap upgrade is takeoff or low milage Hoss2 coilover Bilsteins and a tire size increase 1-2 sizes,
A Subaru can to the stuff mentioned with little stress.
Montana Bronco
Montana
Chevy
I own a Base, it’s a 2023 and I’ve put 48,000 miles on it.
I upgraded tires and wheels immediately, right here on this forums marketplace I bought some Badlands wheels and K02s. During the winter I install actual winter tires.
Base is fine in the winter. My village is at 7,500 feet and gets over 500 inches of snow every winter. You don’t need 4A, 4Hi works great. And you definitely don’t need lockers. Just get good tires and adjust your driving to the conditions.
During the summer I am a fly fishing guide. I beat the heck out of my Bronco, it’s gotten all scraped up from barb wire fences. I don’t care, Broncos are tough and mine works hard. I took the back seat out, best modification ever.
I find it hilarious that my build date was 4/20. In a state with legal weed. So you know those UAW workers were smoked up when my Bronco rolled down the line. Runs great, 7MT is ridiculously fun.
You made a smart move getting a Base.
ducksface
Stroppe
Grand Canyon, Arizona
2025 stroppe
Stroppe
Wear out the factory tires, then decide. You don't know if you're so unable as to have to upgrade. You've seen some awful crap on the road, the tires new on that bronco will suffice.
Buy kilmat.
https://www.amazon.com/s?k=kilmat&crid=2QD3A2191GBMB&sprefix=kilmat,aps,277&ref=nb_sb_noss_1
There is no way to tell you about your abilities melding with Bronco abilities.
Think of all the garbage cars you've seen on the road in the conditions you ask about:
They get by in much less than a base bronco.
If you drive as well as they, you'll be in a vastly superior vehicle, and they're not.
Important question no one asked:
What do you drive now that you're worried about the adequacy of a bronco?
RedDawg
Erik
PHX AZ
A Base works great right out of the box. Easy to moderate off roading shouldn’t be a problem.
