B&O Sub-rattle Final Word?
stut1313
Kentucky
2021 Badlands 4 door, Sasquatch
B&O owners…There are lots of threads about subs, sub choices, sub location, and the annoying sub rattle but nothing I can find seems to be a final solution. Has anyone cured the rattle with the factory speakers? Did the TSB update do it? Is it possible to add only a sub to the tailgate (move it out of side panel) but retain factory amp? Does that stop the rattle? Some final direction would be helpful. I feel like my head is rattling trying to sort through all of the threads. BTW, you guys do fantastic work on your rides!!
WheresMyBronco
Los Angeles
2023 Badlands
From what I've seen, it appears that everyone has a different issue that causes the rattles.
I'd recommend playing something that causes your sub to rattle and feeling around the cargo area to see if pressing on any specific panels reduces the rattle.
For me, I replaced the plastic panel clips with the ones from the TSB, but it still didn't get it where I wanted it to. So I put some sound deadening sheets, sound absorbing foam, and some weatherstripping to absorb some of the vibrations. I also had to put some weatherstripping on the B (or C?) brace's plastic cover as that was causing some buzzing too. Last thing I did was 3D print a cover and screw it into the soft top ready spots on the cargo panels to tighten them down a bit as well.
It's a lot better now, and there are only a few frequencies that come up in my playlists that causes the rattle/buzz at high volumes now.
Many people have just found the mounting bolts loose. Tightening them back up (with a bit of blue loctite for good measure) fixes it for some. (this was what caused my own rattle)
So, there are the clips mentioned in the TSB. I found that using the updated clips the panel was significantly harder to get back off - so be aware of that. (this didn't fix my rattle at all, and made it a giant pain to get the panel back off, but it's done so ...)
Some people have had luck wrapping the sub enclosure / inner surface of the quarter panel in Dynamat. (I did this when I had it apart just because it was there and accessible, and couldn't hurt, but it didn't fix my rattle)
For some, it's not the sub itself rattling, but something nearby - like stuff mounted on a molle panel or tailgate in the back. (I've had this happen before to me as well, but usually easy to figure out - first step in figuring out the rattle is get everything out of the rear end that you possibly can)
I've seen two occurrences of people having a cracked mount on the quarter panel itself and that causing a rattle. So that isn't exactly common but something to look out for
Kinetic
Josh
Savannah GA
2024 Bronco Raptor
Just a hack I've found to identify the source of rattles.
Download an audio sweep app to your phone, turn up your stereo to a fairly loud volume and start adjusting the frequency until you hear the rattle you want to eliminate, go to the source and start pressing on pieces and panels until it stops. Once you find the exact spot it is much easier to fix.
Tukten
Tukten
Denver
2022 4-door Badlands with Sasquatch package
The TSB fixed it for me (sorta) but… I had already taken it to an audio shop to add dynamat, etc. So, it’s not clear if the new fastener from the TSB fix resolved it alone or if it was the new fastener + the dynamat that fixed it.
AJITO
AJ
Baltimore
2022 Bronco Wildtrak
Dynamat the ENTIRE TRUNK!!!!! Just do it and thank yourself later. Also, B&O system is just terrible for what it is. Replace your subwoofer either with another 8” or mount it to the tailgate in an enclosure. These are tried and true methods that are extensively documented all over the forums.
When in doubt, Google it!
stut1313
stut1313
Kentucky
Thank for the reply. I keep thinking dynamat/TSB/move sub are the best combination. And I did google and search here, it’s not that there was no information, there was entirely too much and no real consensus.
jabrax
Willow Grove, Pa
2023 Badlands Sasquatch
I took mine back to Ford after just 2 weeks. They checked and said it needed a new sub. Taking back tomorrow to have it installed, I will report back afterwards
22luxobx
Las Vegas, NV
2018 Ford F-150 SE
I did the TSB and still have rattle. Im about to change to the JL stealth box cause I do like the sub being tucked away in the oem spot as to relocation under back seat or on tailgate. I just need the space when I travel. It is too bad cause I purchased the lux package as all the other fords I’ve owned that had the B&O system worked great and this is the one vehicle I’ve had issues with. Ford dealer just tells me “yeah that’s how they all are” I don’t understand cause first 5-6 months it did great and never rattled. I might look into retightening the bolts and adding lock tite but this is a headache and I’m tired of having to mess with it. Want to enjoy my music on the way to work and on the open road. Can’t believe it’s still an ongoing issue this far into 6G.
BroncoStang
Just curious, anyone know of a good thread on here that shows some steps to take the interior panels off? Or has anyone done it and have any tips or advice?
I'm losing my mind with the subwoofer rattle and I'm ready to Kilmat the entire trunk. Just hesitant about breaking a bunch of the interior panel clips lol
The first few thousand miles were great but this rattle has been getting worse and anything with even a slight amount of bass even at half volume will create an annoying rattle.
stut1313
stut1313
Kentucky
Just FYI. I was messing around with an increasingly bad rattle (hence this thread) and found that the bolt mounting the sub at the ton was loose. A few turns with a wrench and almost 0 rattle.
BroncoStang
I wonder if this is my issue then, it's been increasingly worse almost as if a bolt has been slowly loosening 🤔
lando88
Orlando
https://www.bronco6g.com/forum/thre...de-replacing-upgrading-the-factory-sub.73215/
bstoked
Tim
Golden, Colorado
Subaru Impreza
I just did the same thing and it fixed the issue. While the panel was off I added some sound deadening vibration dampening to the inside of the panel itself (obviously not around the speaker itself) everything sounds super clean now!
BroncoStang
I went through and added Kilmat to mine, my first round didn't solve the rattle then I discovered this.....
Ford Bronco B&O Sub-rattle Final Word? 1000004748
Ford Bronco B&O Sub-rattle Final Word? 1000004746
This explains why the rattle was worsening over time. The mount for this sensor/antenna? was separating from the panel. I used JB plastic weld on it and wrapped it in Kilmat. No more rattle 😎
