Auto Start/Stop Disable Install - What The??
Flying Skunks
Donnie
23 Badlands Sasquash
I just played with this . Works Great , Super Easy to use . Yes it will disable Auto Start/Stop , the annoying double honk and more . Just plug into your OBD2 port , and follow prompts on the screen. Highly recommend. I have already used it on our '23 Bronco Badlands SAS
Ford Bronco Auto Start/Stop Disable Install - What The?? 17082729467932037689201313043033
Broncobren
Matt
WT High Pkg MIC Mod Bumper
I can’t find anywhere that this officially works to stop auto start stop for a 2023?
Mscdman
P
Denver
OBX
I did the ASS eliminator and the Kicker 200.4 with Plugnplaykits harness at the same time. That panel was kind of a bastard to remove, and the radio plugs were difficult to get back in the space with the adapters. The panel went back on just like before.
That’s why I don’t want to mess with it
It’s surprising that you bought it without seeing the installation process, then you’re upset that the install requires more than you expected (What did you base expections on?).
Anyway, as others have said - anyone can do this. I did it in about 10 minutes with most of that time spent pulling off the center panel. It’s very stubborn.
But really - Who buys things without checking to see if they’re willing to tackle the install?
I fully accept I should have watched first. I swore I’d seen a YouTube video of people reaching under the dash to do it.
sorry my mistake bothers you more than it bothers me.
Mscdman
P
Denver
OBX
Install isn't bad. Maybe 45-mins max being very careful.
Installed two of em w no problems - no broken clips or anything
Helps to get Plastic Pry Tool Kit on Amazon for less than $10 - no scratch removal of auto trim panels - and the painter's tape
Here's another Pry Tool Kit - only $6
Grab handle is easiest to remove. Really nothin
For 23's and 24's there aren't many good choices - Forscan doesn't work - SuperChips FlashCal doesn't work - and the Chinese OBD2 plug is flaky
The US made Autostop Eliminator is rock solid w all model year Broncos so far. And none of the other options can say this
That’s the one I bought. US Made Autostop eliminator above.
rskiba
Rob
Pasco, WA
'24 Bronco Badlands, '23 F-350 Super Duty
I installed and removed my AutoStop Eliminator on my '21 Wildtrack without issue. Will be installing into the new '24 Badlands next week. The online video instructions are excellent and the clips seemed to be just fine. Take your time. Watch a step on the video and then perform the step. Going step by step makes it easy and comfortable.
HoosierDaddy
__ Eric
NW. Indiana
i’m pretty mechanically inclined and usually do all the own work on my own car. However, every single time I’ve worked with a car where I’ve tried to remove panels or clips, the clips break and even if they don’t, the panel never goes in as snug as it did before and I really don’t wanna take any chances on a $50,000 car.
LOL, exactly this!
I've completely torn down and rebuilt motors, transmission swaps , etc etc ... I HATE dealing with plastic panels..... but the ASS is so damn annoying on the automatics ... I'd jump into it if I had the part.
But, I'll probably be trading that Bronco off pretty soon, so no reason to do that. I'll leave it unmodified for the next owner.
Rydfree
Benny
Alabama
dpequip
Pickens, SC
23 Bronco OBX 23 Maverick AWD F350 Flatbed 4X4
I've done 2 of these installs on a '22 and '23 Broncos. Vendor provided excellent install video anyone can follow. No big deal just take your time. No scratches or broken clips. The panels popped back into place just like they are supposed to. Most of the time problems with broken clips usually start after the vehicles get some age and are baked in the sun for years. Then plastic can get brittle. I taken plenty of clipped panels off Ford vehicles it's really no big deal as long as you are careful and go slow.
1st 75th ranger
jeffrey
nj
What the heck! I bought the hundred dollar auto start stop disabled eliminator from the USA company assuming that it was just as easy to install as reaching underneath of the dash and installing the new pigtail. However, on their website they’re actually removing panels pulling off the center AC console what a pain I’m not even gonna try and do that, is that really required to install this thing?
I thought this was a simple, plug and play with no panel removal…..
if this does require panels to be removed, you can count me out and if anyone wants to buy a brand new one that hasn’t even been opened. I’m happy to sell you mine
its actually i large undertaking for such a small problem ...good luck
rskiba
Rob
Pasco, WA
Quick Update: The install of the AutoStop into the '24 went without issue. It is not all that bad once you get over the "I am going to break these clips" feeling. The '24 really seems to have some super strong clips but nothing broke and the switch retains it setting - first world problems.....lol.
swamp2
I just installed this one and it takes no panel removal as it installs in the drivers side foot well on the LHS of the vehicle. Works great, no window switch interference others reported and only $45.
Amazon link
Mscdman
P
Denver
OBX
Amazon link.
please let us know over the next few weeks if you notice any window abnormalities. I suspect the reason the more expensive eliminator is behind the from panel is because it isolates the ASS switch vs the footwell one probably having multiple wires flowing through it.
the multiple wires is probably why some report window issues as there might be interference.
but I’m curious
swamp2
but I’m curious
Not quite sure what your speculation is here... More pass through wires in the foot well unit and if they are intermittent or faulty then you get window problems? I will certainly update if any issues.
patientB
Charlotte area
2023 Jeep Wrangler Rubicon Unlimited
I also bought the $45 Amazon solution, the one that requires no panels to be pulled.
Installed it today. I won’t lie, the installation was a female dog…lots of sweating and cursing to get the unit plugged into the slot that is hidden away on the far left of the driver footwell. You’re working blind, and it isn’t easy. But once I got the final “click” of the unit attaching as it should, all was forgiven.
it works flawlessly, remembering the last ASS button position pressed. No issue with the power windows, and they still open via remote, etc.
Very happy with this mod.
