Disable Auto Start Stop on 2024 Bronco ?
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
Procal really doesn't work on the 24? Cause I was gonna order one soon
Procal was recently certified for MY24 vehicles. It doesn’t prevent you from not using premium, you just won’t get full performance without it
beetle
SoCal
2022 Bronco
I always drive in sport mode. After a few months, my Bronco seems to have forgotten how to auto-off when I do forget to put in Sport.
beetle
SoCal
2022 Bronco
Yeah but it's so annoying. The system should have an off setting like you can turn off collision warnings.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I've read in many places in this forum that you have to run premium once you get the tune, which makes sense, otherwise Ford probably would have tuned it that way to begin with. But having no first hand knowledge this could be miss information.
Zybore
Reading, PA
Bronco 2024
Lcubed
l
UsA
I have it installled on my vehicle. The hearsay is incorrect
BRMarshall
BRMarshall
B.R.
Katy, TX
Thanks again for all the feedback. I'd also like to turn off the seat belt reminders so I'm thinking if the ProCal device is capable of doing both, I'd go that route as opposed to spending money on the eliminator device. Can anyone comment on ProCal device being able to disable the both A.S.S and the Seat Belt Reminders for MY 2024?
Ducati1098
The procal won’t disable the seat belt reminder.
But there’s a way to do that without any programmer.
https://www.bronco6g.com/forum/threads/2021-bronco-forscan-thread.844/page-48#post-1399613
StevenSeagull
South Carolina
2024 Badlands
I had zero issue turning seatbelt reminders off on my '24 Badlands with Forscan.
Forscan was 100% worth the ~$40 I spent on it
beetle
SoCal
2022 Bronco
I sure would like a hack that allows always starting in sport mode. Why should I be forced to mess with buttons/dials to have my vehicle do what I want, it's just a little aggravation I don't need.
Apparently, all the trims are able to use all the G.O.A.T. modes if you hack the computer. Someone sells something to do it, it'll void your warranty but Ford doesn't care about covering your warranty anyway. If you do hack the computer, there's an option to default to a mode you like.
BRMarshall
BRMarshall
B.R.
Katy, TX
I was actually able to add Baja Mode with Forscan. Also, I was able to disable the double honk. I wasn't able to disable A.S.S. or the seat belt minders though. Which is why I'm looking for alternatives. So looks like I'll be able to do the seat belt reminders without any special software or hardware using the procedure . I'll just need to buy that harness to get rid of A.S.S. and I'll be happy. Thanks!
BRMarshall
BRMarshall
B.R.
Katy, TX
Interesting, for some reason, it's not showing up as option for me in the "easy mode" I searched for the code referenced in the Forscan spreadsheet, none of my modules included the code #. So, I had no way of even changing anything.
1st 75th ranger
jeffrey
nj
Has anyone successfully disabled auto start stop in a 2024. I've used Forscan to make changes on my 2024, but I'm not able to get the auto stop start modification to work. Any suggestions?
you tube has many options
24wildGumby
Chuck
Branchville NJ
I have a 24 wiltrak 4 door . I installed Procal thinking it would eliminate A.S.S. ! I called the Ford Tech line . They told me they were forced to remove the feature due to gov restrictions with emissions . The literature i had read only covered 21-23. Tried forscan as well with no luck . It works for the first couple stops and reverts back to stock set up . Im getting the eliminator . There’s a $50 difference between the amazon version and others I’ve seen . Does anyone know if theres a difference???
Dsword
Dean
Wisconsin
‘21 Mustang GT Premium - 1998 Jeep Cherokee XJ
When I start mine (after being in Sport), the screen asks me to answer Yes or No to Return to Sport Mode? I answer Yes and don't HAVE to fiddle with the modes, but I still have to press the 2A button versus it going into 4A. When I watch the power distribution screen, it shows power going to all 4 wheels in 4A, which must reduce the fuel mileage.
