ARB Summit install
Doug_life
Oregon
23 wt, 78 bronco
I picked up an ARB Summit bumper a couple of months ago. I've been delaying install for a myriad of reasons (winch indecision, work, vacation, honey do, the tragic mess that is my shop)
I finally have a few days with no obligations. So I figured I'd tackle it.
I'll post short updates as I go. So if you have installed one. Please give some tips!
Firstly, ARB packed this thing like it was going to be ran over by the delivery truck.
Box On a pallet, wrapped in plastic, cardboard paper, then foam wrap.
Ford Bronco ARB Summit install Screenshot_20240702_211908_Gallery
Doug_life
Oregon
23 wt, 78 bronco
I got it unwrapped and up on some saw horses. With the help of my kids.
It is heavy, but worse it is awkward to lift. My old back didn't want to risk being sore.
I read the directions and realized I did not have a 13/32nd drill bit
5 stores and 60 miles later. I was able to locate one. (Partially my fault, since I waited until evening to get started)
Ford Bronco ARB Summit install Screenshot_20240702_211804_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_211815_Gallery
Doug_life
Oregon
23 wt, 78 bronco
I marked the headlight position on my shop door, and expertly marked the tire position.
I'm curious how much height I will lose with the added weight.
The summit is 100 lbs heavier than the mod bumper. But I have a 2 door. Which is lighter than the 4 door. Not sure if the suspension is the same.
Ford Bronco ARB Summit install Screenshot_20240702_211901_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_211853_Gallery
Doug_life
Oregon
23 wt, 78 bronco
I ended up going with the smittybuilt x20.
And holy crap, ARB sends an obnoxiously large sticker!
They are proud of their stuff, but my blind spot is already pretty bad, I don't want to add to it!
Ford Bronco ARB Summit install Screenshot_20240702_213602_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_213620_Gallery
Doug_life
Oregon
23 wt, 78 bronco
The proximity wiring harness proved a slight pita to unhook from the truck. Partially due to my giant paws.
I prevailed though. I did realize the plastic stud/push pins are pretty much single use. Two broke and they marred up pretty bad with removal. Not sure if it was dirt making them difficult to remove.
Ford Bronco ARB Summit install Screenshot_20240702_220923_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_220927_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_220931_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_220937_Gallery
Doug_life
Oregon
23 wt, 78 bronco
Bumper is skinned of the parking sensors. Pretty straight forward. Just a tad tedious.
It took a bit longer because I put the bumper back together while I still knew where the bolts were and how it went back together.
Also, on the harness. Are these the fog light plugs? My mod bumper didn't have fogs. Nor do I have a switch on the headlight.
Ford Bronco ARB Summit install Screenshot_20240702_231913_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_231858_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_231926_Gallery
Doug_life
Oregon
23 wt, 78 bronco
And fyi, my ADHD is at full throttle.
This is a comparison between Griots 3n1 and cerakote ceramic coat.
Paint is 40 years old. First Pic is the raw paint.
Second is riots
Third is cerakote.
Ford Bronco ARB Summit install Screenshot_20240702_232307_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_232303_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_232311_Gallery
Doug_life
Oregon
23 wt, 78 bronco
I'm thinking the directions are not correct for my model.
The directions say to remove the intercooler shutter wiring harness to extend it for the camera.
My camera harness is not included with that harness.
Ford Bronco ARB Summit install Screenshot_20240702_235125_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_235109_Gallery
Ford Bronco ARB Summit install Screenshot_20240702_235209_Gallery
Doug_life
Oregon
23 wt, 78 bronco
Blinkers are wired and lights have power.
Fwiw, I used a pick to put as much pressure as needed to back out the screws in the push pins for the wheel liner. There is soo much dirt in there.
Now onto the intercooler...
Ford Bronco ARB Summit install Screenshot_20240703_021006_Gallery
Ford Bronco ARB Summit install Screenshot_20240703_021020_Gallery
Ford Bronco ARB Summit install Screenshot_20240703_021032_Gallery
Doug_life
Oregon
23 wt, 78 bronco
Got the brackets on! Took 2 hours. Once I realized I should have not removed the bolts. It was 30 minutes.
Now I am trying to figure out the mess of bolts they sent. It was literally a bag of loose nuts and bolts
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
I’m proud of your Bronco dirt. 😉 You should be too!!
Doug_life
Oregon
23 wt, 78 bronco
I went into the house last night to grab another beer. Then I saw is was 4 a.m. !
I called it a night.
My level of frustration is pretty high. The lack of labeling on the individual parts, and the 6 lb bag of loose nuts and bolts that are all similar in size.
I'm starting to figure out why there is not an install video. I was using all the potty words last night!
Doug_life
Oregon
23 wt, 78 bronco
Back at it.
I am trying to figure out which washer to use to tie together the intercooler bracket to the chassis mount brackets.
There are 3 different m10 washers listed. All with slightly different outer diameters
Ford Bronco ARB Summit install Screenshot_20240703_105454_Gallery
Ford Bronco ARB Summit install Screenshot_20240703_105507_Gallery
Ford Bronco ARB Summit install Screenshot_20240703_105710_Gallery
Ford Bronco ARB Summit install Screenshot_20240703_105716_Gallery
