Any consensus on which tailgate reinforcement has performed best?
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
QA processes should be in place to catch stuff like that. Here are two examples where they did not. I understand that things happen but resolving issues quickly and to the satisfaction of customers is a mark of good customer service. 90% of the customers don’t care about plant tours or even an apology from the owner - they want their stuff right or fixed quickly to their satisfaction. On top of that, I don’t care if they get 1000s of emails a day. They need to figure out a way to manage them.
Mine was resolved the moment I called them so I'm happy. The next business, large or small, that I hear about that no one is not happy with....................will be my first.
andersman02
Garrett
Minnesota
Bronco Big Bend 2.7l SaS
Well- Unfortunately I CANNOT recommend the Hammerbuilt system. After 1 winter in MN (BTW a record LOW winter for snow/temps which means very little salt) there is a fair amount of rust forming, mainly in the small nooks and crannies, but also along the edges. It is also pretty bad where the bolts go through, i guess ill give them a pass there as MAYBE the boltshave something to do with it.
Checked a few weeks ago and actually have powdercoat chipping/flaking on the edges, in some pretty big chunks.
Hammerbuilt was receptive and easy enough to talk to about it, but at the end of the day they said it was "Normal" and they do not warranty their powdercoat. They told me it looks likes I'm due for a powder coat refresh, which is absolutely insane as I haven't even had this for 1 year.
It's pretty clear the powdercoat was not up to par. I have a few other powdercoated things, such as a fab fours front bumper that's been through 2 winters, and that has NO rust on it.
Bummer cause I like their system
Roofus
Roofus
Swamp
M3/Bronco
Subdude662
2025 Explorer, 2023 Bronco
FYI, Broncbuster has two photos of hinges that dont match and one is an exact copy of the RTR pic on their site:
Ford Bronco Any consensus on which tailgate reinforcement has performed best? Screenshot 2024-10-13 at 12.30.20 PM
From Broncbuster:
Ford Bronco Any consensus on which tailgate reinforcement has performed best? Screenshot 2024-10-13 at 12.32.28 PM
I am pulling the trigger on either the TOR or the RTR soon, I'm just agonizing over the decision. When you add up the price of the TOR reinforcement and tire carrier its within a couple $$$ of the RTR so thats not helping me make a decision. RTR is a little lighter weight than the TOR combo and looks a bit more sleek vs heavy duty. There seems to be a lot less chatter on the forums and interwebs on the RTR though. Does that mean people buy less of them vs TOR or are just less vocal about their choice?
Anyone have strong feelings for or against the RTR?
Shadowsquatch
GA
Cactus Grey 2-Door Wildtrak
How well do these tire carriers play with the Rakattach? I'm planning to get a Rakattach but I'm concerned that the spare will be further away from the back and possibly interfere with the bikes. Does anyone with one of these tire carriers also have a Rakattach and can comment?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
After digging into some older threads - due to the fact that the Smittybilt isn’t reinforced behind all 4 bolts of the tire carrier - @Turn Offroad won my allegiance. I regret not getting their rear bumper on a daily basis. I didn’t want to make the same mistake twice.
flashpunk
San Francisco
I saw yesterday that that buttercup YouTube channel has some new billet machined hinges available...
They look awesome, but I don't think it's solving the main problem that the bronco rear door has (structural rigidity on that rear panel).
They did mention in the launch video that they will be offering accessories - so perhaps they'll have a reinforcement plate.
Myself - I went with the mountains 2 metal way back when I first got my bronco, and am very happy because of all of the accessory options they have. It even ended up working fine with my x-rack over tire shelf.
Scedwin
'24 Badsquatch, Skateboard
@flashpunk did you have to make any mods to anything for the x-rack over tire shelf? Are you using their shelf brackets too?
flashpunk
San Francisco
No mods needed to install and use as advertised. Im using the full setup from x-rack - so yes I guess that means their shelf brackets. The one thing I did do is to mount the shelf slightly lower is drill out custom height holes, I think it saved me an inch or two.
tjparisi
TJ
Buffalo
2021 Bronco Badlands 4D 7M
Has anyone tried the MetalCloak reinforcement? I’m located in Buffalo NY and there’s an insane amount of road salt and brine used here. Everything steel I’ve put on the back of the truck has had rust issues (Turn Off-road reinforcement, ADD Rock Fighter bumper, etc) so I’m considering switching to an aluminum reinforcement. I’m also curious how any recent IAG installs have gone, looks like there were issues a couple years ago. I have a badlands 6M with Sasquatch wheels and 315 BFG KO2s
Hockeydad55
Tony
Idaho
i Have the Hammerbuilt and no problems so far and carrying a toyo m/t 37” tire. This was suppose to tie me over until I got Turns but it has done so well I have not replaced it and instead got there rear bumper not tire carrier one. One thing to make sure of which ever reinforcement you get it should go behind all tire carrier bolts not just passenger side. Second if you are going to carry a 37” or any heavy tire get the BAM pin support so you don’t get that nasty pin bend.
