Alignment specs for BD with SAS coil overs?
Quest
Massachusetts
2023 Ford Bronco Black Diamond 4DR
Putting Badlands sas coil overs on a Black Diamond non-sas. Would the Alignment specs still be Black Diamond non-sas?
Bronco Don
Don
Rialto, California
Tacoma 4x4
I have a black diamond non- sas, I have bilstien 5100 shocks at 1.5 lift And 4 wheel parts still can not get alignment right. My left tire still wears on the inside.
Fordified1
Bob
Mid South Texas
Ford Bronco Alignment specs for BD with SAS coil overs? 74483512752__BCC38C26-D067-49AD-AF73-6285ADBF50CD
Fordified1
Bob
Mid South Texas
If in doubt use the BD SAS specifications. But I believe they are the same for all Broncos SAS or not.
The above post with pic is from my alignment on a non SAS BD with Eibach pro truck coilovers. Aligned is aligned across the board I believe.
Fordified1
Bob
Mid South Texas
I would use a different alignment shop. If their equipment is off or just inexperienced operator, going back will probably get same results. Does it pull to one side going down the road?
Bronco Don
Don
Rialto, California
Tacoma 4x4
No it drives ok, but even after 300 miles I can already see inside tire wear , im going to Les schwab next week it’s a real bummer that a well known 4x4 shop can’t get it. They’re the ones who installed the lift.
Fordified1
Bob
Mid South Texas
Do you leave it in 4A all the time?
Bronco Don
Don
Rialto, California
Tacoma 4x4
No I do not have 4A, just a lot of highway driving to work and I can already see some in even wear.
dgorsett
colorado
F250, Mustang, Explorer
Interesting. I did 5100s at 1.5. My eye and hillbilly carpenters level alignment looked good so I never took it in. Drives great no odd wear 10K + miles.
Definitely go against the grain on alignments, if it ain't broke don't fix it (they'll probably break it) and I seldom rotate tires.
Bronco Don
Don
Rialto, California
Tacoma 4x4
Well I hope the new alignment next week will solve my problems because I’m tired of wearing out that tire
