Sas takeoff shocks - which alignment specs??
Black_Stallion13
Cincinnati
Tacoma
I installed factory sas takeoff Billsteins on my standard Big Bend this past weekend and now I need to get an alignment done… the issue is I’m not sure which model specs to use for said alignment.
I have the standard factory Badlands wheels (non beadlock) with 33” KO2s installed, so my initial thought was to go with the standard Badlands alignment spec, but that doesn’t account for the extra height of the sas version Bilsteins that I have since non sas badlands shocks have the shorter bump stops (.4” lower overall).
Then I figured maybe the sas package settings make more sense since those r the shocks I have (even though I’m only running 33s and not the 35s).
THEN I realized that the Wildtraks from 2022 and prior which also used to have the same sas style Bilsteins also have their own specs which actually match the non sas trims other than badlands - this detail makes me wonder if the sway bar disconnect/front locker on badlands & sas package affect the alignment specs. If that is the case, maybe Wildtrak specs below are actually most correct for me since I have the Bilsteins but no front locker/sway bar disconnect on my Big Bend.
I’m not an alignment guru and just want to make sure this gets done right - eager to know what others who have installed sas takeoffs have done. Was going to take to Ford dealer if I can figure out which model specs to use, but maybe a shop that can do custom alignments would be better?
Alignment Specifications
NOTE:
Measurements listed at curb load. Curb load is defined as full service fluids, full fuel tank(s), no passengers and no cargo.
ItemLHRHTotal / Split
FRONT SUSPENSION
CASTER - BASE, MID - BIG BEND, PREMIUM - OUTER BANKS, WILDTRACK, BLACK DIAMOND SERIES vehicles3.47° ± 0.60°3.47° ± 0.60°0.0° ± 0.70°
CASTER - BADLANDS SERIES vehicles3.35° ± 0.60°3.35° ± 0.60°0.0° ± 0.70°
CASTER - ADRENALINE RUSH PACKAGE - HERITAGE STANDARD, OVERLAND, WILDTRACK UPGRADE SERIES vehicles3.18° ± 0.60°3.18° ± 0.60°0.0° ± 0.70°
CAMBER - BASE, MID - BIG BEND, PREMIUM - OUTER BANKS, WILDTRACK, BLACK DIAMOND SERIES vehicles-0.23° ± 0.50°-0.23° ± 0.50°0.0° ± 0.70°
CAMBER - BADLANDS SERIES vehicles0.12° ± 0.50°0.12° ± 0.50°0.0° ± 0.70°
CAMBER - ADRENALINE RUSH PACKAGE - HERITAGE STANDARD, OVERLAND, WILDTRACK UPGRADE SERIES vehicles0.20° ± 0.50°0.20° ± 0.50°0.0° ± 0.70°
Toe - (positive value is toe in, negative value is toe out) - All Vehicles0.20° ± 0.20°
REAR SUSPENSION (Audit specifications - For reference purposes only)
CAMBER - All Vehicles0.00° ± 0.75°0.00° ± 0.75°
Toe - (positive value is toe in, negative value is toe out) - All Vehicles0.22° ± 0.20°
Thrust Angle0.00° ± 0.50°
rtaylor
R
ID
19Raptor, 22Bronco
Align to the SAS (Adrenaline Rush) specs. It's the control arm angle (shock length at ride height) that matters. Also note that if the alignment is close to the target SAS spec, it typically falls within the spec range for all trims anyway.
Black_Stallion13
Black_Stallion13
Cincinnati
Tacoma
Thanks! Used SAS specs and looks great. Probably a case of overthinking it haha
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
... Probably a case of overthinking it haha
Oh absolutely 😋
A competent alignment tech should be able to put something on the rack and align it without needing to read pages of manufacturer mumbo jumbo like you posted.
I lifted my BB lifted with 2" spacers and had a small local garage align it... tires are wearing infinitely better than on my '21 ranger which I had exclusively dealer serviced lol.
