SAS takeoff compatibility question
Wen
Wendell
Chevy Tahoe
Sorry if this was already asked and if there is already a thread please post.
Im shopping SAS suspension takeoffs and im curious if any, meaning trim and door type, SAS coilovers will fit my 2 door non SAS black diamond?
also, is there any additional hardware i will need or would this be a direct replacement?
thanks.
MNBigfoot
MN
thanks.
Different string rates depending on trim/engines/tow package, etc, all dealing with weight. With that being said, I believe that all will work. If you want to add an aftermarket bumper or winch, you may not want the exact replacement for your trim. Someone has a chart with the different spring-rates/parts-numbers based on those factors.
flip
Phil
IN
www.ruxerparts.com
Fords
You should try to find a set that has the same configuration (engine, transmission, tow/no tow, number of doors) as yours.
Wen
Wendell
Chevy Tahoe
thanks man. i'll look for the chart
Wen
Wendell
Chevy Tahoe
makes sense. they all say it will fit but i guess they just want to dump them lol
one is throwing in the UCAs. i think e is replacing all of it but is there any difference with the SAS and non SAS UCAs?
flip
Phil
IN
www.ruxerparts.com
Fords
UCAs are the same on all models.
DM me your VIN and I'll look up specs and tell you what to look for.
  • Like
Reactions: Wen
F OR D
BD Green Machine
  • Like
Reactions: Wen
Wen
Wendell
Chevy Tahoe
thanks man
Wen
Wendell
Chevy Tahoe
