- Joined
- Aug 14, 2024
- Threads
- 58
- Messages
- 483
- Reaction score
- 823
- Location
- United States
- Vehicle(s)
- 2024 2DR Badlands Manual/VB, 2018 F-150 Lariat/3.5EB, 2013 Mustang GT DIB
- Your Bronco Model
- Badlands
I should really do a chalk test.2-Doors tend to run about 3-5 psi higher than 4-doors from what I've seen, with most 2-doors at 39 and 4-doors at 35 on the sticker. Also note there is a difference between cold and hot pressures on a tire, and that can vary by 2-5 psi, and it can change a bit with altitude as well.
That said, look up something called "Chalk Testing" - it's super simple to do, and optimizes your tire pressure for tire longevity (not fuel economy). Just need a piece of sidewalk chalk and a little stretch of flat pavement. On my larger tires, chalk test showed 28 cold, but I run them at 30 on the street - a compromise between a more comfortable ride / tire life and fuel economy.
You can also use Forscan to adjust when the low tire pressure warning comes on, if you care to adjust that as well.
