74WELD RACK for Bronco Raptor arrived!
Raptor911
Raptor911
Broadlands, VA
I also spoke to them also .. $3900 total if I were to drive to them.
they would remove the OEM rack and swap out the internals into the 74Weld rack and reinstall and also get an alignment.
I spoke to 74weld today, currently looking at a June 1st release date. The rack will sell for $4900, but if you already have a Bronco Raptor you will be able to reuse your factory rack guts as you already have the HOSS 3.0 rack. They propose you send them your rack and have them swap your internals over and then they ship it back to you. They won't sell just a housing because the electronics removal and installation is a fairly technical procedure. Doing this route saves you $1900 off that price so the cost would only be 3K for the rack.
swamp2
Hoping to have the bronco back from the dealer next week and will post install pics. I should not be breaking anymore racks now!!!
Get it installed?
Curious if 74Weld knows as to where the overall system weak point moves to with both updated rack and beefed up tie rods?
I guess stock it is rack first then tie rods? Seems like the reverse of that would be better.
TheBraptor
Will
UTAH
2022 Bronco Raptor 1972 Ford Bronco
