37s on a 2.3L?
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
"Sport Mode keeps the transmission from ever shifting into 9th or 10th gear, so it effectively like an electronic re-gear of the rear axle."
Not really. You electronically made your 10 speed an 8 speed.
You are correct. I mis-spoke. I guess the point I was trying to make is that by driving in Sport mode, you can run 37's on the 3.73 without having to physically change anything else. And while @Snacktime is correct about Normal and Eco modes being miserable (MPG's are terrible, too), Sport mode is actually quite pleasant and fuel economy is surprisingly good.
BroncGal
BroncGal
Kim
Ford Bronco
I want 38's for the 1.5" of clearance, not for the tire size (geez they're expensive when they get big). I don't think 37's look all that different, either, but to each their own.
If I were looking for a cosmetic update, I'd start with the rims and wait for the tires to wear out before I changed them up.
This is definitely the plan so far 👍🏼
userdude
Denton, TX
2023 2dr Badsquatch
Another cheaper but good upgrade for beaching it up is a sunshade when the top comes off. A lot of them can even stay on with the top on. I just helped put one on a JLU and the difference from the sun above was pretty big. I like with the doors off but not the sun beating down. There's all kinds of designs too.
BroncGal
BroncGal
Kim
Ford Bronco
Just installed mine this week and started using it 😊 I left it installed with the soft top on with no problems. Also waiting on my tailgate fold down table to come in. 😎
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
Don't listen to these practical opinions. Get a lift under there. Get some wheels with a little more offset (maybe 0 or -12) and get some 37s. Lets Go!!!
Post pics.
If you find it to be sluggish, get some bigger gearing.
When I start looking at 37s, I start thinking about 40s.
BroncGal
BroncGal
Kim
Ford Bronco
Post pics.
This is what I came here to hear! 🙌👏 LETS GOOOOO
beetle
SoCal
2022 Bronco
So... how would I know what my Bronco was geared to? I'm the second owner and It's an Outer Banks, non-Sas
Beachin 74
Delaware
If you have a rear locker switch on top of the dashboard you have 4.27. If you don't have a rear locker, you have 3.73.
LOSTXGOLD
TEO
GARLAND, TX
www.lostxgold.com
2023 Area 51 Base Sasquatch 2.7
Post pics.
37’s, -12 offset - Sasquatch + Eibach lift springs.
Ford Bronco 37s on a 2.3L? IMG_3119
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
Thanks for sharing @LOSTXGOLD There you go, @BroncGal
same color and everything. I love the internet.
Since your original post was about engine/power/tire diameter, and since my opinion differs slightly from the consensus in this thread, I'll give you my experience.
I have the 2.3 with the 7 speed manual transmission. I have a non-sas badlands so I have the 4.7 rear end. I can't speak to the 10 speed auto and the low gears, but I can tell you that I like the way my rig drives better on stock 33s than it does on the 35x13.5s I have on it. For capability reasons, I'd never go backwards. And they look great too. But I sometimes switch the stockies back on (like when I'm bringing it in for warranty work on the front end). And I am always bummed about how much more juice it has out of the hole with the smaller tires.
I often think about re-doing the suspension and going 37s. And sometimes 40s. But given my experience from 33s to 35s, I would definitely re-gear if I went to 37s. Like I wrote, I know that is different than much of the feedback on this thread.
Just to give you the other side, people will argue that the raptor comes on 37s and it has 4.7 axles. -but it does have a much more powerful engine.
And I also think I have read that moving to a bigger final drive ratio than 4.7 might be more challenging than swapping in some gears. There are definitely threads on this forum on that topic.
But looking at lostxgold's pic above, how can you not? Fun fun. 37s are the new 35s.
LOSTXGOLD
TEO
GARLAND, TX
www.lostxgold.com
I will say, it has lost its agility. I do like the way the 35’s felt vs the 37’s.
Personally it feels slightly slower. Which makes sense, because of the heavy 37’s.
I do like the look better than the 35’s, so it just depends on personal preference.
I’ll try to find lighter 37’s the next go around.
BroncGal
BroncGal
Kim
Ford Bronco
Did you add the lift springs for the clearance? Do you know how much of a lift it gave?
What load rating do yours have? Based on the recommendations here I have been looking at C and D.
LOSTXGOLD
TEO
GARLAND, TX
www.lostxgold.com
Yes, I added the lift springs for clearance to fit the 37’s.
I’ll double check on the load rating, it might be F. Which was an accident. There was load D, and F.
It added a lift of: Front: +2.3" Rear: +1.6"
