35s or 37s…?
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
Look at the first link with all the pics 37s just completely change the look but thats no lift once you add the lift its actually harder to see the difference due to you are further from the finders. Now I have 1 3/8s front and 1in rear lift and 38s the level of clean now is on another level. Lets keep in mind I have Sasquatch so you 2in is about the same as my 1 3/8s lift but 38s take some extra work.
37s
https://www.bronco6g.com/forum/thre...asquatch-badlands-no-lift-build-thread.26479/
38s
https://www.bronco6g.com/forum/thre...badlands-2in-lift-build-thread-round-2.48983/
37s KM3s
Ford Bronco 35s or 37s…? IMG_8165-3
38s 1 3/8 lift Patagonia
Ford Bronco 35s or 37s…? IMG_3557-2
35s Stock
Ford Bronco 35s or 37s…? IMG_8161-2
Ford Bronco 35s or 37s…? IMG_8159-3
NDM_84
Nedim
Richmond, Virginia
Camaro SS
I’m biased towards 37s.
BF Goodrich KM3s are small 37s. Think about this 37x13.50 KM3 is a 81.4lb tire, E-10 Ply, max load 3195lbs where as a 35x12.50 Nitto Trail Grappler is a 79.9 lbs tire, E-10 Ply, and a max load rating of 3195lbs. I even looked up the true size and BFG KMR is 36.5X13.6 and the Nitto Trail Grappler is 34.85X13.19. How do you make sense of only a 1.5lb weight difference on these tires.
HeliPilot
Kenny
CT
2022 2.7L SAS
I ran Nittos on my TRX. I could never keep them balanced. Because of this, I refused to put them on my Bronco. 18,000 mile on them and they’ve never required a rebalance. The Nittos were back at a tire shop every 3-4 months. I found it extremely annoying. As far as weight goes, they are two totally different compounds. The KM3s remain soft and pliable in cold temps. The Nittos get rock hard.
raqball
Kris
WA
2023 Ford Bronco Badlands 2DR
My non sas Badlands has 34's and it does just fine off-road. I take it off-roading once or twice a month so it's not a mall build..
I think you'd be fine with 35's..
Ford Bronco 35s or 37s…? 20240413_141528
TT6gbd
Eddie
Orange County
2022 ford bronco
I just got mine back from the shop yesterday. I did the Eibach Stage 2 lift, and put BFG 37x12.5. It looks so much better than the stock 33s!
How does it drive going from 33s to 37s? What’s your gearing? Did you do any adjustments on Eibach coilovers or are they left on outbox settings? Asking because I have a same setup but debating on 37s
brycedan
Idaho
Eruption Green Badlans Lux Tow Hardtop
I have the manual transmission so it has the lower gearing. It rides really good. I know the shop adjusted the Eibachs some. I'm pretty sure the front is close to maxed out on lift. I also got the ford performance tune. It did wonders, and I was able to adjust the speedometer to work with the larger tires.
TT6gbd
Eddie
Orange County
2022 ford bronco
good to know it rides good with these shocks. I just didn’t want to raise the front more then how the coilovers come out of the box in order to keep oem upper control arms. How’s the alignment?
