3.0 Steering Rack Install Issues
CH02
Chad
Kennesaw
2021 Outer Banks Sasquatch
The shop put the rack in and has it plugged in but when running the rack file program in the tuner this is what happens. Any thoughts?
Ford Bronco 3.0 Steering Rack Install Issues PXL_20240828_135900023
PWillette
Parrie
Maine
BigMeatsBronco
Allan
2021 FE 2 door
Did the shop download the actual tune onto the device from Ford performance?
CH02
CH02
Chad
Kennesaw
I did all the downloads before taking it over. The files show up on the tuner itself.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
@Snacktime is the steering rack guru.
When it comes to the ProCal it's a bunch of 4 letter words. I haven't successfully used a ProCal to program a rack and why I was interested in your Bronco. The whole process is unnerving as the ProCal rack programming seems to be hit or miss.
CH02
CH02
Chad
Kennesaw
So at some point between putting the upgrade files on the ProCal and running the rack upgrade process it deleted the original rack files. The tech at FP asked for pics of a couple menus in the ProCal and came back a few hours later with a solution to plug the tuner into the PC without logging into the app then running the upgrade on the Bronco. Took a few minutes to run and I was back on the road.
AJITO
AJ
Baltimore
2022 Bronco Wildtrak
I had a similar issue happen with my 3.0 w/74 weld stage 1. The download code was almost thrown out with the box too!
But after taking the ProCal to the shop, entering the key to download the rack file, and then trying to upload it into the Bronco, it was not picking up the file and said something similar to what you have above.
I eventually figured out that I needed to grab the most recent Bronco data/backup the Broncos stock calibration file through ProCal. I did have issues performing the Rack Upgrade while the new rack was on. When the system booted back up, I still had a bunch of check advancetrac and service 4x4 DTCs. I ultimately had to connect my ProCal back to my computer and have it apply the rack upgrade to the backup that was created when I clicked “Rack Upgrade”.
If you still run into errors, download Forscan, apply for a temp key (1 months) and clear your DTCs using Forscan and an OBD 2.0 cable connected to your laptop and car.
If you lost your ASBUILT, and it won't proceed any further, you can also download the ASBUILT data. https://www.motorcraftservice.com/AsBuilt
Razorback
Dallas
Lincoln MKX
Question: I'm having the HOSS 3.0 and stage 2 74Weld rack put in this next week. Is there a market for a HOSS 2.0 rack with 37k miles, or just leave it with the shop?
CH02
CH02
Chad
Kennesaw
No idea honestly. Mine is sitting in the garage.
Razorback
Dallas
Lincoln MKX
I don't know whether to travel back home for 4 hours with it or not. Even then I would probably only be able to sell it local since shipping would probably make it cost prohibited to sell it.
userdude
Denton, TX
2023 2dr Badsquatch
I still have mine after a year. Whose going to buy it? Someone who busted their 2.0 and doesn't want to upgrade or wants a backup in case (and wants to store it). It's not worthless, but it's a thin market. With the 74W rack, I just don't need it except out of my garage...
brnc_o_vrlndr
Casey
Southeast Michigan
2021 Ford Bronco Badlands 4-dr non-Sasquatch 7-spd
I tried to perform the rack upgrade last night and was met with the same screen as the OP. After some back and forth with the Procal and computer, I found that the original rack was no longer reporting a part number under the "Module Info" Procal menu screen. After trying a few more things, I decided I would just write the original As-Built information back into the original rack and start over. In Forscan, I noticed that the PSCM only shows the menu for programmable parameters and NOT the as-built interface for it. So, I cannot flash the original PSCM with original as-built. I will reach out to FP tomorrow, but does anyone know how to get back the As-Built interface for a module in Forscan? Is there a way to blanket-load all module as-built information from the Motorcraft as-built file?
You save all the files before you touch them. That's really the only way to get "as-builts"
Even the web site, that is named "As-Built" - gets updated with OTA information. So if you make a change, the web site version will get updated in ... a few days/weeks? to reflect the change.
As far as the PSCM - that's physically part of the rack. And part of the problem, since the new rack comes with a completely blank/unprogrammed module and Ford is relying on the ProCal unit to populate it (and does a horrible job of it). If you put the old rack back in, it should still have all the original programming.
