2dr hardtop leak
SeaVee
Greg
Va Beach
2002 2500 Suburban, 77 Bronco, 2001 Cherokee
My 2022 2dr seems to leak a little when it rains. Always the same 2 places ( one on each side) Not a ton of water but it leaks. Water accumulates where you see it but can’t tell where it’s coming from. Top was off one time, front panels maybe 3 times. Any thoughts? TIA
Ford Bronco 2dr hardtop leak 3B28E94C-ABC9-430A-BC92-3F73A1B68E4F
Ford Bronco 2dr hardtop leak F4860158-FB82-4065-8AB1-5A5E490FE852
smiths65
Niskayuna, NY 12309
'21 RAM1500 BigHorn
Had something similar with mine...turned out to be bad window seal/seating at factory. Glass shop repair
Monster1926
GMC Sierra 2500HD
Have this on my 23 as well.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
I have this exact same issue on my 2021 Badlands. @Ford Motor Company can you help open a case on this for me?
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Ford Motor Company
Dearborn
CarGuy
New Jersey
2023 Ford Bronco
I have the same exact issue on my ‘23 Wildtrak. I have not discussed with the dealer yet, but plan to when I schedule service soon.
Ford Bronco 2dr hardtop leak IMG_1185
Ford Bronco 2dr hardtop leak IMG_1184
Ford Motor Company
Dearborn
Good morning, John! I would be glad to help you out with this hardtop leak if you are still needing assistance. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
@Ford Motor Company These tops have been a real quality problem. I’m not going to opine on if it is a design or manufacturing fault but there is no denying the issue.
What is going to happen to all of us who haven’t had a problem yet but will have an issue when the warranty expires after 3 years? This is a major and very expensive component of the car. It is reasonable to expect it to last the life of the car and not fail in a few years.
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
I have the same issue on my 22, but it only happens on one side. Always the same spot though. It's not concerning enough for me to take it in to a dealer though.
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
This.
I'll add, the papier-mache hardtop issues are one of several reasons that I'm holding off buying one of these. I have one of those lives, and I'd be guaranteed to get a turd.
(that I can no longer order what I wanted is another major factor)
carrellslake
Oregon
2022 Ford Bronco
I had that leak too. The dealership reinstalled the window and the leak stopped. It will be warranty covered.
nytjoo
Julian
same issue 23 badlands 2door dealer took it though the wash and said “unable to duplicate concern” pretty unhappy.
Ford Bronco 2dr hardtop leak IMG_4781
BadCactus
Derek
West Linn, OR
2021 2-Door Badland 2.3L 7M | 1991 EB
Hi @Ford Motor Company ! Thank you for the quick response to my concern. I ended up figuring out how to address the issue. Here's how:
  1. I suspected the cause could be a poor seal to the B-Pillar from a change in temperature since the top was last reinstalled in warm weather.
  2. I loosened the hard top mounting bolts and the rear latches on the roof panels.
  3. I then went to the back of the vehicle and gently pushed the top toward the front at the two C-Pillar locations.
  4. I tightened down the mounting bolts and secured the rear roof panel latches.
And.......all fixed! There have been several hard rains since the adjustments were made, and there are no drips along the window. If anything changes, I will certainly let you know. Happy New Year!
Derek
