Raptor18
2020 F-250 Tremor, 2021 Bronco
Has anyone been able to disable auto start-stop? I get the following error. I am in PSCM 730-03-01. No error codes.
I just did it and had zero issues. Are you using a Bluetooth of Wi-Fi adapter?
Boston182
San Francisco, California
Harley Davidson Sportster
I can't wait to annoy one of you to spoon-feed me on how to do this in the future.
I'm used to flashing ECU's on motorcycles. I assume this is similar?
Alright, you turkeys (Thanksgiving joke, don't ban me)
Cable comes tomorrow. Looking forward to Sport Mode and killing that horn honk when I get out of the car. Also looking forward to having my hand-held through the process of the brain surgery on my FE.
@D2dhanover No joke, let me Venmo you enough for a case of beer or something. This thread is nuts and it's mostly due to your hard work.
BD1
BD1
IL
No using usb and all my other changes worked (e.g. sport mode on badlands, double honk)
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
HD radio enable? Is it a simple toggle in FORscan or is there additional hardware required?
CCross
Cory
Arkansas
2007 Chevy 2500HD Duramax, 2000 Jeep Wrangler
I’ve got everything connected and created backups of all the “as-builds”. When making updates, do I update the “as-built” module or the “non as-built” module. Ex. “BdyCM Module Configuration (AS BUILT format” vs “BdyCM Module Configuration”?
Klunatic
F250
Update the as built, did you check out the Forscan tutorial and embedded videos? Lots of good info on how to make changes. I also recommend logging before and after changes. I take screen shots before and after with each change and save in a word doc.
Alfie623
Alfie
Newburgh, NY
1983 Bronco
Here’s an update from my Bronco. To turn off the ”doo doo doo” for the key-in chime and the door ajar chime the changes are in IPC but on line 720-01-02 rather than 720-02-01 as listed in the spreadsheet. The following worked for me:
720-01-02 xxxx x*xx changed from 0 to 2 to turn off the key-in chime
720-01-02 xx*x xxxx changed from 2 to 0 to turn off the door ajar chime
regarding the door ajar, I still see a warning on the dash that a door is open.
hope this helps.
Alfie623
Alfie
Newburgh, NY
1983 Bronco
I have saved my changes in notes and after a few days I’ll save my current as-builts to a new folder, once I know I like them, and this will be my reference point in case I need to restore or reset anything.
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
hope this helps.
Updated the sheet. Please review and let me know. I had it highlighted as I wasn't certain.
Thank you for the feedback.
Tidy2000
Jon
STL
2017 Ford F150 Raptor SCrew
I've used Forscan on my Raptor last, about a year ago. I was getting this error when trying to add Baja to a BD.
Found out, all I needed to do was update to the most current version of Forscan on my Win10 laptop. All good after that.
Alfie623
Alfie
Newburgh, NY
1983 Bronco
Just reviewed and all looks to be the way I made my changes. Thanks for updating it, I wasn’t sure if it was something I could do or if it’s locked.
Klunatic
F250
Try loading your Bronco as a new vehicle Profile into FORScan.
I know some people have stated that trying to close all four windows at once just doesn’t work period. Could be why Global Close was never included. You should be able to try it again and close the front two. My Broncos will close all 4 so far, knock on wood. I’ve only done it a couple times just to test/demonstrate
I had the drivers window stop on one if the global command close. I suspect it's part of the window safety feature. The window will stop closing if they sense resistance. It may be Ford turned up the sensitivity when the windows are closed remotely. It only happened once, just to be safe I send the close wait 10 seconds and send it again if I am not standing next to the vehicle.
mattm54
Katonah, NY
None
Ok an interesting thing happened when I had completed all programming steps. The first time I pushed the lock button, then pushed it again and held it down all the windows closed at the same time. The second and subsequent times I tried it the rear windows closed perfectly but the fronts stopped at different spots. I again had to press the lock button, then press it again and hold it down to get the fronts to close. Any ideas as to what’s happening?
Happened to me too.. I did the window reset which fixed for me… for the windows causing issue open it and hold button down for ten seconds, then close and hold button for ten seconds … repeat two more times … this also fixed my rear window which wasn’t functioning properly when door was opened then closed…. Thought the fix was an April fools joke or something but worked for me .. good luck
Klunatic
F250
What is "the window reset"
