TeeBone
Tom
Northern VA
Ram 1500
Has anyone explored attempting to change the temperature of the heated steering wheel? I read this was doable on the F150.
Noticing my heated steering wheel is lukewarm at best now that it’s getting colder out.
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
I posted in another Thread about that that it is listed with a pull-down menu for a choice of temperatures I am fine with the temperature of my wheel so I did not change it
Ford Bronco 2021+ Bronco ForScan Thread 1636898575186249845389195524769
mpeugeot
35 C = 95 F, You madman!!!!
Related to the GOAT Mode Thread... OMG the sky is falling... Ford is going to take away all the heating options... and plug all the Forscan loopholes... What about the children... I swear, I see more doubt, uncertainty, and self-inflicted fear around Forscan use.
amccue90
Andrew
Illinois
2021 Badlands
You made me nervous thinking Ford actually responded, vs a single person claiming they've stopped this before
Panzer948
Charlotte, NC
www.youtube.com
1981 CJ5, 2015 BMW M4, 2023 Mach E GT PE
This is great, I actually think mine gets to hot and turn it off after only a minute. When I get Forscan setup I will adjust this down for sure.
bytheway
Brice
Louisville, KY
What’s the last thing on the spreadsheet about navigation in motion with Lincoln 13.2” etc? I was curious but didn’t want to fool with something I wasn’t sure what it was. I’d like the nav in motion but don’t want to lose 911 assist.
bytheway
Brice
Louisville, KY
I don’t suggest doing the navigation in motion it will take away 911 assist. It basically is saying you’re in another country (not by GPS that will still work but just the default programming feature location)
Regarding the Lincoln thing, someone asked about doing a Lincoln theme instead of the Ford. Normally this is relatively easy but Lincoln’s have different screen sizes (10” and 13.2”) and only one vehicle in Lincoln right now has Sync 4 like the Bronco and that’s a Navigator with the 13.2” screen. The aspect ratio is different so while you might be able to use the theme I worry it would also try to use the aspect ratio for the 13.2”. I haven’t had a chance to test any of that yet. Been kind of busy to be doing any programming research.
thanks. Initially I plugged in to check for DTCs since I didn’t clear them when adding goat modes. Nothing related to the sport mode change. There was one error about no signal from right spotlight indicator or something but I tried it and it turned right on. Maybe something left over from when I took my doors off. Ended up turning up my heated steering wheel a few degrees while I was connected. So far so good.
privateer35
Seattle
Ford Bronco 2021
I have read through most of this and is very intriguing. My first item was changing tire size but I assume any reputable tire shop would do this at install (wishful thinking?)
Anyway, the other options have peaked my interest and leads me to my question.
Who has used Forscan with iOS? Is it as capable? Is buying a Windows based laptop Worth it just to use Forscan?
I am a MAC user and haven't used a window based system in over a decade. I value any insight or experience. TY
Look into windows boot camp.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
SUCCESS:
Double Honk
Door Chime
Key Chime
Baja Mode
FAILURE:
Auto Stop Start (PSCM)
Seat Belts (IPC)
Could be user error and I’ll have to give these a shot again once the MX+ adapter works again. I’ve reached out to support but in case anyone else is familiar with the MX+, the Bluetooth connection is paired and connected but the adapter won’t connect to the vehicle. I’ve tried two laptops and same thing. Will update with proper diagnosis and solution, hopefully.
MAC USERS:
The Crossover app works great, it’s the solution linked on the Forscan page, and it’s easy to install.
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
SUCCESS:
Double Honk
Door Chime
Key Chime
Baja Mode
FAILURE:
Seat Belts (IPC)
MAC USERS:
Thank you for the update as to what's working/not - updating spreadsheet to show multi success.
For the bluetooth, have the vehicle in Aux mode, then verify in Windows (looks like your a Mac so a VM or bootcamp) that its connected to bluetooth, then try connecting forscan to the vehicle. My old MX+ (wifi) adapter use to have challenges till I upgraded to the MX+ (now bluetooth only)
for the failure, can you confirm that you updated the below? Also what was your original number?
Disable Auto Start-StopPSCM730-03-01xxxxxxxx**--Start / Stop: 00=Disabled 01=Enabled, Angle Inhibit Enabled 02=Enabled, Angle Inhibit Disabled
Disable driver & passenger seatbelt minderIPC720-01-01xxxxxx*xxx--0 = Disable both; 2 = Disable drivers; 4 = disable passenger
Blue's B6G
Jeremy
Los Angeles
This has to be possible, we’ve seen it for almost a year now but still no one has cracked the code.
This is the grail.
Ford Bronco 2021+ Bronco ForScan Thread 1637376436844
Ford Bronco 2021+ Bronco ForScan Thread 1637376463165
Eric L
2020 Explorer ST, 2017 Fusion Sport
My Badsquatch now has Sport mode and no double honk. Thanks!!!
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Using Forscan on my 2019 Raptor I was able to change the blinker from from 3 to 5 when changing lanes. Does anyone know if that will work with the Bronco? Thanks.
