red75bronco
Frank
2025 Badlands, 1975 Bronco
I want to see if anyone else is seeing this. Added sport mode last night to 25 badlands. Everything works good. When I scroll to rock crawl, everything works, but the label rock crawl doesn’t show up? The icon with the rocks does and everything seems to work. Anyone else run across this?
je1279
Upstate NY
2025 Bronco Badlands Sasquatch
I can check when my wife gets home as I added that to hers last week. The only change that didn't work was auto stop/start removal (which I later learned was not possible via Forscan for the recent model years) so Im going to get her the Autostop Eliminator for that.
PayHeedKU
Kansas
2025 CRV, 2000 Dodge Dakota, 2025 Bandlands (ordered)
I can check when my wife gets home as I added that to hers last week. The only change that didn't work was auto start stop removal so Im going to get the 4D Tech eliminator for that.
Does she have a 2025? Did you try to get rid of the chimes for teh seatbelts and door ajar alerts? I attempted to do that and wasn’t able to.
je1279
Upstate NY
She does. I removed the double honk on exit while running, but not any of the other chimes/alerts
PayHeedKU
Kansas
As I suspected it was user error - tried it again this afternoon and it worked fine. Also I’m seeing the same thing with Sport mode added - Rock Crawling disappears. Guess the display only has room for so many modes. I’m guessing there’s no way to re-order the modes is there?
je1279
Upstate NY
Same here. @PayHeedKU I also confirmed that the Rock Crawl G.O.A.T. screen no longer has labels after adding Sport mode.
Ford Bronco 2021+ Bronco ForScan Thread 1000002451
BadmansSAS
2024 Bronco WildTrak
It doesn’t display because you have too many modes. Mine did that. Disabled eco and all the modes showed up (except eco).
je1279
Upstate NY
This seems very odd to me. On my '23 F150, enabling other modes doesn't have any impact on the factory modes.
Acewizard
LUCIAN
Kentucky
2023 Bronco 4 Door 2.7 ecoboost / 2017 Mustang 5.0 GT
Just used forscan to change rear speakers to speaker + sub. Added Baja mode, Slippery mode and removed ECO mode. Added windows roll up and down with key fob. Everything is backed up and working fine. This was a lot easier than I thought it would be.
Dover157
Ben
Moriarty NM
2022 Bronco Black Diamond
Ok on my first real road trip with my 22 BD and discovered that the settings I had previously done for tire size were just a bit off. Figured no problem have the laptop and cable with me will just tweak it a little. Now im getting a DTC, SODCMC 160A:00-2F.
Running version 2.3.65, did the AWD relearn but there is no longer an option for PMC relearn.
SODCMC keeps failing when I try to open it. Did try doing SODCMC reboot with no change. Any ideas what im missing on the new version?
Was able to fix my issue when I got home. Thought it odd it was giving me an error in SODCMC when my 22 black diamond does not even have the mid package and has no sensors for side object detection. Hooked up again and pulled a fresh read instead of using the preexisting template on my laptop. It then showed the error in PCM as open/closed loop on the fuel injection. Relearn cleared the code and all is well. So if your having issues do a fresh pull of the modules. Side note does anyone know which speaker is #6? I’m getting a DTC in the audio module saying open circuit.
je1279
Upstate NY
I do not, but I had that same DTC recently also. I cleared it and it has not yet come back.
