- First Name
- Chris
- Joined
- Mar 6, 2021
- Threads
- 75
- Messages
- 4,769
- Reaction score
- 5,201
- Location
- Cold Spring, NY
- Vehicle(s)
- 2021 Bronco, 2020 Ranger
- Your Bronco Model
- Black Diamond
I’m having the same issue trying to disable Key in Ignition Chime. No matter what I do…easy method or code.I’ve seen a person or two having the same issue I have, but no solution so far. When I go into the IPC section to disable the chimes, it keeps giving me the “service procedure interrupted” error. It worked fine on the Body BcS module and I could disable the double honk, but anything I try to do in IPC gives me the error. I’ve got the OBDLink EX that everyone else seems to use, I’ve downloaded and reinstalled Forscan and the updated drivers and firmware for the cable. Anyone have any thoughts?
