BroncoPQ
Canada, Quebec
Audi SQ5
SO... has anyone created the Bronco Forscan spreadsheet yet? :) Was hoping someone has.. but after reading thru all the comments.. either I missed it.. or it hasnt been done yet.. :)
So where is that sheet?
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
WuNgUn
Ontario Canada
2 door Squatched
I just put one together. I'm certain I missed something. Let me know if there's something you have tested and outcome. Also provide your Bronco Model.
FORScan - 21+ Bronco
I hope this is helpful.
These are just the settings that you manually have to edit, correct? It's been awhile since I looked at Forscan... Is it "as built" options where you just toggle them on and off? Like Bambi mode?
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
I see the front/rear fog lights didnt make the list yet.. :)
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
gizmohd
Darren
hollapm
Paul
SoCal
Correct, these are in the As-built area of forscan.
mds5917
New Jersey
Does anyone know if there are other screen modes or themes that can be invoked? The day (really bright) and night (too dark for some areas during the day with sunglasses) are a bit limiting. Thought they might have some other options, but cannot seem to find them so thinking there might be some in FORScan...or hope, anyway.
VictoryLights
Pittsburgh
2018 Honda Pilot
Would somebody mind finding out which audio options are available? I.e. for adding a subwoofer to the base system?
hollapm
Paul
SoCal
mds5917
New Jersey
I added the Fog Light to the sheet. Note that the links provided didn't use the As-Built portion, so I linked to where others have done, and then added areas in light orange as to what will likely need to be changed in As-Built
Thanks - yes, the “as-built” were noted on his work, so all others were just plain.
amccue90
Andrew
Illinois
2021 Badlands
the disable doo doo doo at startup per the f150 spreadsheet works. not sure if that was different then the key in ignition one
Ok I think I disabled the seatbelt minder, but I have the doors off. When I put the car in drive, without a seatbelt on, chimes go crazy, only display warning is "transmission in park".
Does anybody know if the disable seatbelt minder only works with the doors on? I'll find out when I put the doors back on if I did it right, but figured I'd ask in case someone knows.
hollapm
Paul
SoCal
What line from the F150 did you use? Looking to update the spreadsheet and see a couple of them which have sounds. Was it one of these?
Disables door ajar chimeIPC720-01-02xx0xxx--
Disable key-in ignition chimeIPC720-02-01xx*xxxxxxx--subtract 8 from current value (if E change to 6)
