WuNgUn
Ontario Canada
2 door Squatched
This may be a long shot... Seeing as the center display splash screen can be changed (Lincoln, Mustang, etc) is it possible to have the new Lincoln warning chimes instead of the old, annoying Ford warning chimes? Lol
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
My brother and I played around yesterday, was able to kill the double honk. We thought we had disabled ASS, but it came back on this morning. Are there multiple locations to disable it, or am I missing something?
thanks!
BroncoFE1
Wes
Missouri
2019 Ford F150 Diesel
thanks!
I only saw one location for it, did you go out and drive it and it still was on? I ask because it just tricks the system into thinking that the steering wheel is being moved and turns the ASS off.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
thanks!
Did your lights flash and you were sure to disconnect Forscan, shut off engine and restart ignition?
KnoxGnater
Nat
Knoxville, TN
Nope, but we will do that sequence Friday, thanks for the tip.
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
SO... has anyone created the Bronco Forscan spreadsheet yet? :) Was hoping someone has.. but after reading thru all the comments.. either I missed it.. or it hasnt been done yet.. :)
Akinmx
Memphis, TN
2006 Ford F150, 2011 Ford Fusion
@Airborne_Ape
Thanks for your input! Most of what you said goes over my head and I would need a whole day to read and learn about it. But from what I understand, would it be possible to enable... let's say.... the Ford "connected built-in navigation" to your Bronco if you only had the high package? Connected built-in navigation comes standard on the lux package but assuming there are no additional parts needed... could Forscan simply turn that option on so that one could have constant navigation? And yes I know I could easily link my phone to Sync and use a navigation app on my phone but I'm just curious if it can also be done this way? Thanks!
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
This thread is by far interesting!
Have anyone found how to play with the GOAT modes? Adding for example MUD or Baja to those trims that doesn't have them?
Perhaps it's just to hardcore to see that on the system and as you might already guess I'm truly NOT an expert on this....YET.
CliffCo
Cliff
Charlotte
2021 Iconic Silver, Big Bend Sasquatch (MIC top)
Yeah, I'm liking this idea... Programmers respond!
Bkbk
Mn
Fiesta
@Airborne_Ape
I used forscan to enable navigation on my fiesta st and it works great. I'm sure we'll be able to figure it out for the bronco eventually
WuNgUn
Ontario Canada
2 door Squatched
@Airborne_Ape
As far as I know, 'built in' only means a 3 year subscription instead of a 90 day subscription. The hardware and functionality are the same as the connected, high package option.
amccue90
Andrew
Illinois
2021 Badlands
I used the F150 spreadsheet mentioned in this thread and changed the following (all successful)
Disable Double Horn Honk (THANK YOU!!!!)
Disable seatbelt reminder
Disable door ajar chime (still chimes once...but not endlessly)
Disable key-in ignition chime
Set Remote Window Open/Close in Sync 4
I have to kill these chimes and the double honk. Making my wife and dogs crazy. Pretty nervous to check it out, but I wanted to ask if the alerts still show up on the dash?
Like I don't need a constant chime as I roll my Bronc down the drive with my door open, but would like an on screen alert that the rear door wasn't closed properly after dropping a friend off.
gizmohd
Darren
Better than my wife's sport... if you try and roll the vehicle with the doors open it immedately puts the vehicle in park and sets the parking brake... lol
