2.7 tuner vs procal
gfdiver69
MT
Question: I'm looking at purchasing a tuner for the 2.7 from Ford Performance since they have 20% off until the end of the month. Reading through the description M-12655-F ProCal 4 is listed as a part that may be needed???
Will the tuner work without the M-12655-F part? What is the M-12655-F?
Thank you for the information
Ducati1098
M-12655-F is the procal only. Doesn’t include a tune, and you cannot buy one separately.
That’s not what you need.
You have to buy the specific calibration for your vehicle, which includes the procal
Ford Bronco 2.7 tuner vs procal IMG_7032
gfdiver69
MT
LethalPerformance
Jared
South Florida
www.lethalperformance.com
As another stated, the ProCal itself (the device) is that part number. It comes with the full kit:
https://www.lethalperformance.com/f...ry-tool-2021-2024-bronco-2-7l-m-9603-b27.html
We have these at $695 and be sure to use coupon code "FBFAN" at checkout.. These are in stock with 2-day shipping.
I personally used this tuner on my Wildtrak and it was a night and day change for the transmission tuning. The power gains are worth it, too. All in all an easy to use but effective product.
-Logan
MEDISN
I highly recommend the ProCal w/tune - I purchased from LethalPerformance. The best $600 I've spent on my '23 Wildrak. Less throttle lag, holds gears longer and shifts fast. Plus auto stop start memory (stays wherever you set it) and full factory warranty. It turns the fun factor of the Bronco up to 11. It's really the way it should have been tuned from the factory. If I have to replace the Bronco tomorrow it will be my first upgrade, no question.
WildOne23
James
Bloomingdale, IL
Lexus GS 350
Perhaps an ignorant question, but how does a tune like this work in the different drive modes? I also have a 23 Wildtrak - so would this tune bump up normal mode, and sport? Does it affect eco mode?
MEDISN
You still have all the modes like ECO, but with additional HP/TQ. Shift points are better mapped so rarely hunting for gears. The biggest difference is it makes Normal mode a lot more responsive for daily driving and Sport mode has more power available.
In ECO mode I saw no difference in MPG before/after. In Normal mode you will see a slight decrease in fuel economy because you will be hot-dogging it with a smile on your face. Interstate driving I saw no difference in fuel economy. This is on the 2.7L w/SAS.
WildOne23
James
Bloomingdale, IL
Lexus GS 350
great, thank you for the help.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
I agree with Medisn - considering you can keep your warranty the ProCal tune to me is a no-brainer. I also got from Lethal (with a sale it was around $550 I believe). As others have said the improvements in the shifting alone are worth it. The throttle response and power increase was noticeable to me.
scranda
Knoxville
2023 Bronco Wildtrak
-Logan
Does the Procal tuner require a PC for install or can a MAC be used—does it require a windows based PC?
Thanks.
GA2Dr
Marietta, GA
Thanks.
I am not sure, sorry. I had a shop install because Ford says a dealership or ASE certified tech must install to keep the warranty. Not sure if it's true but I wasn't taking a chance.
Combustion_King
Derek
MA
Yes
it makes all the modes better. and it will keep auto start turned off when you push the button.
GA2Dr
Marietta, GA
I wish the A-S-S would stay off but it does not on my '24. Apparently it does on earlier years.
Combustion_King
Derek
MA
Yes
Your pro cal doesn't keep the ASS off? my23 hasnt been on in over a year.
GA2Dr
Marietta, GA
Nope, wish it did. Also tried to disable it with Forscan and no luck. Others have had the same experience on here apparently.
