2.7 tuner vs procal
Combustion_King
Derek
MA
Yes
Nope, wish it did. Also tried to disable it with Forscan and no luck. Others have had the same experience on here apparently.
yea i had no luck with FORscan either. You notice a difference in the drive? you sure they installed the tune.. LOL never know these days.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
Oh yes it was very apparent the difference when I picked it up. First time I hit it on a slight curve the traction control kicked on - never happened before. The difference in the shifting is worth it alone.
Combustion_King
Derek
MA
Yes
one of the best mods for sure. should been stock... but $$$ lol
JL8jeff
Ewing, NJ
Does the Procal tuner require a PC for install or can a MAC be used—does it require a windows based PC?
Thanks.
From their website "***NOTE*** ProCal 4 software only available for Windows 7 or greater. Will NOT work with Windows 10 in "S Mode"."
You need a PC to download the software then with the voucher that comes with the Procal you doenload the specific tune. Then you go to your truck and download the stock tune and take it back to the PC to upload (I think it sends your stock tune to the FPP servers so it can be retrieved in an emergency). Then you upload the tune from the Procal to your truck. You don't need your PC to connect directly to the truck, you take the Procal back and forth from the PC to the truck.
scranda
Knoxville
2023 Bronco Wildtrak
Thanks for clarifying.
