2.5 coilovers making noise
Atoledo95
Alan
Los Angeles, CA
2022 Ford Bronco Outerbanks
Hey Everyone,
I got my Radflo coilovers installed on my 2DR about a month ago but they make a lot of noise. At first I’m like it’ll break in once I break them in. Asked also they said they might need lubricant and got them checked and they said they’re installed right. That’s how coilovers are there noisy, but when I go over bumpers the rear once make noise and when I turn they make noise as well. Just wanted to ask what some ppl think, before I Jack it up this week and check everything again. Thanks y’all.
PWillette
Parrie
Maine
Hey Everyone,
What sort of noise are you hearing? My Eibachs don't make a peep.
Atoledo95
Atoledo95
Alan
Los Angeles, CA
It’s like clunk noises but somewhat also hard to explain how it sounds when going over bumps and doing turns.
PWillette
Parrie
Maine
The only noise issue I had was up front when turning...I was fully maxed out on shock height which caused the steering stops to catch the spindle and make a hell of a racket. Ended up having to adjust down about 1/2" and all is good. How much lift are the Radflos?
Atoledo95
Atoledo95
Alan
Los Angeles, CA
I think maxed out about 2in but even before I had the height adjusted it was already making that noise.
PWillette
Parrie
Maine
Head-scratcher, new coil overs shouldn't be noisy/clunky. I'd reach out to Radflo tech support if you haven't already done so.
Atoledo95
Atoledo95
Alan
Los Angeles, CA
I have already, they said check the preload but was making noise before I did it. They said to adjust my tire pressure to 35psi which is default for broncos. But to make sure the install ion was correct. Might double check it this weekend or go to them.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Might want to double check that all bolts are Torqued down correctly? The rear lower shock bolts are crazy amount of torque to tighten. Might want to take it to another shop in the area to double check the one that installed them?
Atoledo95
Atoledo95
Alan
Los Angeles, CA
I did and the guy said it was fine, so might try another shop nearby.
BryantC
Bryant
Edmonton
I am running radflo on my 4dr. No clunking noises.
BryantC
Bryant
Edmonton
Are yours the extended travel for the sas?
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
If you hear noises when the suspension drops out, you could be hearing the shock hitting the end stops. Fairly normal. If you hear clunking from the shocks during normal driving, like someone else said check all of the blots etc to make certain they are tight. You can also go get the pressure in the shocks checked. if they are low (<50psi) the reservoir piston will make a bit of noise.
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
I’m going to just get mine taken off and lubed and reinstalled and hope they dont
Not sure what you are planning to lube.
Are you able to narrow it down to front vs rear? Sometimes the slider on a dual rate coilover (rear) can stick a little and cause some odd noises. If you are able to rock the vehicle back and forth and recreate the noise, may be worth having a friend help you locate the noise.
