2.3L 7sp badlands engine stopped on freeway
Tricky Mike
21 Bronco
So your saying the pump assembly can be removed and exchanged with fuel in the tank without a spill?
If it's 100% full you'll probably spill some, but 3/4 should be fine.
bf4445
Britt
Oregon
2007LarietCC4x4, 2018FocusTit, 2016Jeep reneTH
When the assembly is removed doesnt that make a hole in the bottom of the tank untill the new one is inserted?
Tricky Mike
21 Bronco
Nope the only holes in the tank are on the top.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
If you have never replaced a fuel pump of any kind , you will want to let the dealership take care of this for you.
bf4445
Britt
Oregon
I've never replaced any in the fuel tank only under the hood
bf4445
Britt
Oregon
Nope, the lines won't even be connected to the tank during the job.
so when the pump is removed what keeps the fuel from leaking out?
bf4445
Britt
Oregon
You said the pump was removed from the top right? So if the top and bottom are open what keeps the fuel inside?
Lifeliberty
Moonbeam👀
Columbus, OH
The bottom is never opened, there's no penetration or anything on the bottom of the tank.
The top has penetrations for the filler line, and a relatively large opening for the fuel pump/level detection assembly to drop down into (that has a gasketed cover that bolts on)
Stealing image from Ford Parts:
The part in the box is the fuel pump/level assembly
Ford Bronco 2.3L 7sp badlands engine stopped on freeway Untitled
bf4445
Britt
Oregon
Ahh...thanks, boy was I out to lunch.
Seems like years ago i changed a pump with a similar arrangment from inside the vehicle. There was an access plate when removed allowed the assembly to be removed without removing the tank.....maybe was a German car???...don't remember
Dosen't look like a bad design except for having to remove the tank.
