2.3L engine dead
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Apparently it was the thrust bearing off the cam shaft.
Crankshaft thrust bearing, hence the excessive crank endplay. Generally, cams don't have thrust bearings.
VirginiaHeritage
Frank
‘25 Bronco HE
I think the forum reply function could use a feature that says something like:
“The thread you are about to reply to has been inactive for more than two years. Are you sure you want to continue?”
