Window Limit Reset Not Working - Now What?
PRA4SNW
Dennis
GA
2018 Flex
I've read about this common issue and how to fix it, even watched 4 different YouTube videos with the same solution:
Hold the window down switch for 10 seconds, then hold the window up switch for 10 seconds to reset the window limits.
Details of my issue:
My 2 door '22 Bronco sat for over 2 months and the battery went flat, needing a jump start to get it going.
After doing this, the driver's door window will not drop when the door is opened and raise when closed. Passenger door is fine.
I had a Mini Cooper that this happened too all the time and had the same fix.
With the Bronco, the repair is not working. I have tried several times in a row.
I saw a comment to disconnect the negative battery terminal for an hour and that was no help.
I have read where a window motor may be needed, but I really think it is electrical in nature and this reset should work.
If there is any advice out there, I would love to hear it.
I am with the vehicle for the weekend, then have to travel back home and won't be able to get it to the dealership in time before I leave, so hoping for a do it yourself solution.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Dennis! I can look into your bronco's window concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your bronco's VIN?
Sinnin7
Josh
Washington State
2024 Badlands 2dr
There is also an update you can have the dealer do which will lower them when you hit the unlock button on your key fob as well. They added for 2024 but i have seen others get the update that have previous years.
You can also try this -
Carry out all steps within 30 seconds of starting the sequence.
  1. Close the window.
  2. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for two seconds.
  3. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for two seconds.
  4. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a two seconds.
  5. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a two seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
PRA4SNW
PRA4SNW
Dennis
GA
2018 Flex
Message sent.
Thanks.
PRA4SNW
PRA4SNW
Dennis
GA
2018 Flex
This is pretty much what I have been doing, and tried it several times in a row. I was holding it up/down for longer, though, so I will give it another try with 2 seconds.
I like the idea of an update with the key fob because right now, the only way I have for keeping the driver's door glass sealed is to exit from the passenger side. There seems to be no way to exit the drivers side and force the glass to seal. And since I have to leave the vehicle in NH for another month or so, I do not want the interior exposed to the elements.
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
My driver’s side window needs to be reset every week. I have had numerous BMWs and Porsches with frameless windows that work the same way and never once did any of them need to be reset nor was it an issue that came up on those forums.
WheresMyBronco
Los Angeles
2023 Badlands
Even my mustang with frameless windows wasn't this bad. I really don't understand why they couldn't get it down this time.
Mr Bacon Jr
Gary
Santa Fe, NM
Yeti SB130
Getting the whole procedure done within 30 seconds is key. I missed that part and spent an hour or more f-ing with it until I figured it out.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S, 14 JK Rubicon
Also, try this with the door open, then closing the door, and various combinations thereof. My passenger rear door sometimes gets out of battery (stuck down 1" even after reset) and doing some combination with opening and closing the door is the only fix
Dmorty217
Derek
Venice FL
Camery
Your window motors need replaced. Just had mine replaced on my driver front and rear and the problem is no more. You should only have to do the reset process once and if the issue comes back then your dealership needs to replace the motors.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
Does it go up and down? I don't understand the issue.
PRA4SNW
PRA4SNW
Dennis
GA
2018 Flex
This is exactly what worked for me. I followed the above procedure - doing it 2 times up and 2 times down and holding it for only 2 seconds instead of 4+ - and getting it done in less than 30 seconds, and it fixed the issue.
I did it while my wife was driving the vehicle, just to try something different.
Thanks to all who responded. If this keeps happening, I will take it to the dealership for a more in depth examination of the issue.
swamp2
I was able to get a successful reset using the rear windows switch but not the front. Afterwards, both switches worked fine for intermittent and full click.
chopperbobby
bob
northern ky
2025 bronco
2025 under 3 weeks old driver window i have to grab it to get it to go up. Bery cold here so at dirst i noticed the window was bery slow the 1st quater going up then appears normal the rest of the way. Thought cold. Then notixe getring slower in 1st quarter going up. Now goes up about 2 inches stops goes back down. 0 degrees window down no good. Had to pull up on winsow button grab the window with both hands to get it up.
not a great start to a new bronco. Got rid of the ram because of maintenance problems. But it had 130,000 on it and sid not cost a thing until the past 2 months.
taking it in on Tuesday
hope this is it
