Why can’t we order the HOSS 3.0 suspensions as accessory?
broncosor
2022 Bronco Badlands
The HOSS 3.0 has been out for a while. I am wondering why can’t we order a set of those with dealers to put on other Sasquatch trims?
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
You can take the part numbers to your parts department and order the pieces in. Some assembly may be required 😜 Google/search bar will yield results
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I'm sure you can order them as parts and not accessories. I'm sire it would be a hot seller if Ford put it as an accessories.
WT205
Matt
Alabama
BMW
If I wasn't getting a WT, I probably wouldn't spend that money on it. Better aftermarket options- including even beefier than Hoss 3.0 tie rods. I guess if you really wanted the 3.0 steering rack but I'm skeptical about how that is so much better than stock anyway...
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
there's a thread elsewhere on this forum where they ordered and received the parts,
but are waiting for the ford software update required for the steering rack et al.
broncosor
broncosor
I am talking about the shocks not the steering rack and tie rods.
I know you can buy kings and fox for $5-6000 but they lift the vehicle which I don’t want and are expensive. If the HOSS 3.0 suspension was selling for 2500-3000 as an accessory I would buy those.
I am looking for better suspension performance and less bottoming out. I don’t want to lift my vehicle and worsen my center of gravity.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
broncosor
broncosor
Lcubed
l
UsA
Those you can order right from your parts dept. They aren't "Live valve", so they would just bolt on. I was replying to @Lcubed
The steering rack is part of the hoss 3.0 upgrade.
Sethtsmith
Seth
2012 F-150 FX2 Supercab
The main reason it is not an accessory that you can order yet is because there is a software component that is upgraded as well. Ford has not released this programming (or created it as far I know). The other thread cited above goes into great detail on the issue.
broncosor
broncosor
When you order the Wildtrak from the factory yes.
I am looking at ordering the Fox Shocks from the dealer for someone who already has a Bronco.
Lcubed
l
UsA
got it. you're really looking for HOSS 2.33
shocks
no upgraded tie rods
no upgraded steering rack
