Which CV shaft is correct.
EGBUCKER
Joey
2023 Bronco
2023 Wildtrak
I need to replace my passenger side side Front cv axle. The part # on the factory front passenger cv shaft is MB3W-3A427-AD. However, when searching for new OEM, it seems that this part # pulls up the front left (driver side) . The parts websites list the 428 version as the right side.
Can someone help me make sense? I always order parts as the passenger side being the right side, am I just confused?
Ford Bronco Which CV shaft is correct. 1736225458051-qg
EGBUCKER
Joey
2023 Bronco
Thanks. It sure would be helpful if they just kept them the same. Even the barcode you can scan on it sends you the left side with the "427" in the part #.
87-Z28
Andy
BMW
@Ducati1098
I am currently doing an m190 to m210 swap. I just got the m210 mounted today. I have RCV CV half shafts I got from another member. Trying to figure out which is which. One has a longer spline stub shaft on the diff side. I would think that is for passenger side intermediate shaft? Just trying to make sure that is correct? Haven’t found a good answer searching around.
Ducati1098
@Ducati1098
Yes, longer one will be for the passenger side
GI_Jo_Nathan
Jonathan
Just out of curiosity was it mpeugeot that you got them from?
GI_Jo_Nathan
Jonathan
No it was not.
Okay cool figured, I figured that would have been a long shot coincidence. I had ended up with a set of rcvs when I got my second hand m210 for my swap. Decided not to use them and sold them to. I knew he was out of Texas and thought it would have been interesting if they ended up on yours.
