Wheel bearing issues
RedBeard-421
Dj
Kentucky
23 bronco
Hey y’all, I’m surprised by the lack of information I’ve found on the wheel bearings. My truck is a non sas black diamond. Lifted with 35s. We do take it off road too, it’s my daily driver. 42k and I’ve got a wheel bearings gone bad. Hopefully ford will cover it under warranty. Is anyone else not having wheel bearing failures? There’s only one YouTube video I came across.
andersman02
Garrett
Minnesota
Bronco Big Bend 2.7l SaS
Doesn't seem to be an issue, however it's relatively new platform so I'm guessing the next year or so you may be seeing more videos once more roll over 100k+ miles
What offset and tires?
RedBeard-421
RedBeard-421
Dj
Kentucky
23 bronco
I was on Kendra klever rt 35x10.5x17. Wheels are the Everglades style wheels. Ran those tires for 40k miles or so.
PWillette
Parrie
Maine
First I've heard of any wheel bearings issues. Doubtful it will be covered under warranty. Fairly easy DIY if you have the tools.
Valhalla
Valhalla
Chattanooga Tn
Do you see a lot of mud offroad? Mud eats bearings.. Those seals keep grease in, not always water out in my off roading experience. Most older 4x4 manuals called for all fluids to be changed each time fording water and mud. No one was doing that, but it was the recommendation.
BlueBronco
DFW
Just here for the inevitable dealer warranty denial due to aftermarket modifications.
Good news is a replacement bearing is relatively cheap and a couple hours worth of work. Just tackle it the next time you rotate your tires.
dgorsett
colorado
F250, Mustang, Explorer
Front I'm assuming? Glad to hear warranty coverage, standard warranty or ESP? I vote modular wheel bearing as the number four automotive improvement in my lifetime (behind fuel injection disk brakes and electronic ignition). I still have bad dreams about tearing a front hub apart to pack every 10K praying I would not find any surprises and not screw it up.
RedBeard-421
RedBeard-421
Dj
Kentucky
23 bronco
Factory warranty
93_SVT_3503
JJ
BFE
2016 F150, 1967 Bronco U-14, 1993 Mustang Cobra
I'm betting they told you the warranty will cover it to get you in the door. Once they see the lift and tires on a non-sas, they'll give you the price quote of what it's going to cost to have them fixed there and they won't even bother trying to file the warranty claim. Unfortunately, this is what most Dealershits have come to lately. Good luck
RedBeard-421
RedBeard-421
Dj
Kentucky
23 bronco
Good thing wheel bearing isn’t hard to change out. I’ll just buy a pair off rock auto or something. Though this same dealership, do take 4 hours to do an alignment
Ford Bronco Wheel bearing issues 1770161223528-wy
Valhalla
Valhalla
Chattanooga Tn
Welp, dealership said it was the fdu. Going to replace it. And, covered under warranty! 42k miles
I've had 2 replaced, all within the first 3 months. this one has been fine!
