What genius at Ford?
Moto26
Tucson AZ
OP dude, post a pic.
^This.
OP is getting a lot of shit here, but a picture of his trailer and hitch would go a long way toward people being able to help…
OCNORB1974
Dale
Missouri
2022 Maverick
Idk what you are pulling but every boat trailer Ive towed with my Bronco has required taking off the tire so the safety pin doesnt hit the tire/bottom of tailgate
Is all you have to do is by an extension, doesn’t take a “genius” to figure that out.
Scott R Nelson
Meridian, ID
OP is getting a lot of crap here, but a picture of his trailer and hitch would go a long way toward people being able to help…
Nah, we're here to ridicule...
...at least for the stuff with obvious easy solutions like this one.
Herewegoagain
Maxemus
Idaho
Honda civic
Who the F### at Ford design the rear of the Bronco to make it f%%%%ng useless for towing unless you remove the spare tire every time
*I have factory tow package
It doesn't matter because Donkies are pretty much useless for towing anything !
2023bronco
location
vehicles
Add "Indecipherable shitting on Ford without photos" to the categories of posts that get the most attention.
#1Broncogirl
Carey
NW MT
2-Broncos, F250, E350, D90
Yes it’s a pain in the A**, but if you just use a short hitch extension that helps.. I agree whoever designed that section obviously never towed anything before🤔😢
Rocky905
Boulder County
2023 BADLANDS non-SAS
That, or you can get an extender.
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
I don't want solutions, I just want to be angry.
This is useful at least in that I'll have to check it the hitch I use on the Flex is incompatible with the Bronco. Never considered the spare getting in the way because we normally use the Flex for towing anyway
Scoop
Gary
Cuchara, Colorado
2026 Stroppe Edition, '74, '76, & '78 Broncos
The Bronco was designed for off-road use. It was not designed to be a tow vehicle. Same general design as a Wrangler. It works fine with a short extension.
OP needs to apologize to the Ford engineers for an uninformed post.
Reidt131
Reid
Howell, MI
Bronco Big Bend
I've pulled my teardrop trailer and also my quad trailer since day 1 with no issues,well only issue is can't open rear door when pulling trailer because they thought copying Jeep would be smart instead of a drop down tailgate :mad:
Wouldn't a drop down tailgate just smash into the hitch? On the F150 there is a bit more vertical space to accommodate the hitch, but with the lower load floor of the Bronco there is limited space.
I guess you would be able to crack the tailgate a bit, but that would still be really awkward to remove items from.
Reidt131
Reid
Howell, MI
Bronco Big Bend
I've had to remove the spare to tow a small camper with an electric jack that was in the way. I also had to remove it to tow a U-haul 6x12 enclosed trailer. Did not have to remove to tow an open motorcycle trailer from Uhaul.
What gets me is the location of the wiring - I've had to remove the wiring bracket to get my bike rack threaded pin in.
Is it a One-up rack? I noticed the same lack of space, but I was able to sneak the pin up and over the 7 pin connector to get it in the hole.
Reidt131
Reid
Howell, MI
Bronco Big Bend
Would have been interesting how a drop down tailgate with spare tire would have worked on a Bronco.
Would have to be an external tire carrier that still swings to the right, mounted to the bumper. At least that's how the older ones did it.
I wonder what crash rating stuff came into play when choosing which tailgate/carrier design to go with?
