- Joined
- Dec 15, 2020
- Threads
- 106
- Messages
- 4,860
- Reaction score
- 9,178
- Location
- Portland, Oregon
- Vehicle(s)
- Mustang
- Your Bronco Model
- Badlands
So you used the ARB cover for the port?
I am running this: https://morrflate.com/shop/air-sour...fivesix-portable-12v-off-road-air-compressor/I just bought a MORRFlate TenSix and just got a chance to use it last weekend. Everything set up, aired up from 20-37psi and packed back up in 11 mins! It used to take me 15 mins PER WHEEL with my cheap compressor. Highly recommend it, very easy to use and a huge quality of life improvement.
With this: https://morrflate.com/shop/morrflate-multi-tire-air-kits/morrflate-duo-2-tire-air-kit/
I went with the smaller compressor so I can use it with my motorcycle tires as well, and the two hose kit because I didn't want the rats nest of coiling up four hoses. Not as fast as the big boy you have, but way better than doing one tire at a time, cheaper than on-board air, and you don't need to carry the weight when you don't need it.
how is the inflate time per tire with that?I have the Ford Performance portable ARB single compressor. Got it for free with Ford points. Will probably remove it from the portable box and mount it to the bronco someplace someday.
I'm sure everything mentioned in this thread will do the trick, they will all inflate your tires, some even at 300 LPM, but the best value in the game hasn't been talked about.
Sounds really good!!After studying all of the available choices, I chose the Smittybilt 2781. The photos below show my setup and what it looks like in action. It takes me three minutes to drop my tire pressure from 39 to 20 with the hose system that I built. The pump gets all four tires back up to 39 psi in ten minutes. These are the 35 inch Sasquatch tires, so it should be faster with smaller tires.
I've seen all kinds of claims with various pump systems, but few actually list how long it takes to inflate all four tires. I've done mine a couple of dozen times and I time it right at ten minutes every time. The pump was around $150 and the hoses also around $150, so I have right around $300 invested. And it all fits in a small corner behind the rear seat in my 2-door.
I have not used it on a single tire. I built my own moreflate setup.how is the inflate time per tire with that?
https://www.bronco6g.com/forum/threads/multi-tire-inflation-for-your-trickflate.73217/post-1933730What air compressors do you all use out there to inflate/deflate tires?
One of the most popular setups we see is our KR Off-Road Mouning System used with an ARB Compressor Under the hood. It's the fastest and most elegant system out there.What air compressors do you all use out there to inflate/deflate tires?
