What Air Compressor do you use?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
PTTyler
Tyler
Lodi, CA
powertank.com
2022 Badlands Sasquatch
Fast, Reliable CO2.
2dr Bronco Mount (Driver side only):
Ford Bronco What Air Compressor do you use? CHA03418_d983d1dc-46c5-4d36-9b51-bd5062b96e56
4dr Bronco Mount (Driver or Passenger side):
Ford Bronco What Air Compressor do you use? 085A5957y (Large)
Benefits over an air compressor:
Fast - compare 45 cfm (cubic feet per minute) of a HP250 Power Tank regulator vs 6.5-10.6 cfm of the fastest compressors. We routinely see sub-five minute air ups after a trail. This is from the time your butt leaves the driver seat to the time you restart the engine to go home. Less time at the trailhead means more time on the trail.
Powerful - the same high volume and constant flow of CO2 allows you to reseat tires faster and more safely than any other method. We've reseated a 46" tire on the trail. You can also run air tools and while electric has certainly caught up in most situations, for really tough jobs, nothing beats being able to turn up the regulator and hitting stubborn fasteners with an air impact.
Reliable - there are no mechanical parts to wear out and no electrical parts to fry. We regularly hear from long time customers that have been using their Power Tank for over 20 years. It's the only air system backed by a limited lifetime warranty.
Portable - because there are no electrical connections to hook up or plumbing to install, you can easily remove your Power Tank and walk it up the trail to reseat a popped bead on someone else's rig or bring it in the home to run an air nailer or blow out sprinkler lines. This also means you can buy one Power Tank and move it between vehicles.
Economical - all Power Tank packages come complete as ready to run kits so keep that in mind when comparing prices. We've been wheeling since 96. If we were running compressors, we likely would have had to buy at least 3-4 replacements over that time vs a single Power Tank.
Rebuildable - because of the higher pressures and flow rates of a Power Tank, we must build every component of a Power Tank to a higher spec ourselves, including accessories like our Tire Inflator Gauges. That means it's trivial to repair or upgrade over time. Want to upgrade your gauge from analog to digital? No problem. Want to trade in your regulator? We have a trade-in program for that.
A 10 lb Power Tank has the useable energy equivalent of 400 gallons of compressed air and can refill 16+ OEM Sasquatch tires from 15 to 35 psi in about 40 seconds a tire.
Yes, you have to pay for CO2 but you're also running your engine and burning gas while your compressor is running. Power Tanks can be refilled at beverage carbonics, homebrew shops, welding shops, fire extinguisher safety services, and hydroponics stores.
CM81
NA
Woot. Bring on all the businesses to flood a thread with what they think is the best, or should I say the ones with the highest profit margin.
What else are people carrying on their rig, you know regular people not trying to sell the most expensive thing.
swooshdave
Portland, Oregon
Mustang
Fast, Reliable CO2.
The one drawback for me is the amount of space it takes up.
PTTyler
Tyler
Lodi, CA
powertank.com
I'll keep my shilling to one reply per thread maximum. I'm not big on hijacking threads, either, but with all the compressor threads, I wouldn't be doing my job if I didn't reply to at least one of them.
j_marinelli
Spring Branch, TX.
I grabbed the single ARB kit with my ford pass points.
Ford Bronco What Air Compressor do you use? 20220405_153925
Paired with a DIY 4 hose kit I made.
Ford Bronco What Air Compressor do you use? 20220407_064027
Felix808
SRV CA
I've been rocking my Viair 400P for 17+ years & it's still pumping up my 37's all at once so I'm not looking to replace it anytime soon. If I was looking to buy a compressor, I would be looking at a twin compressor (faster) & more than likely one that can't be mentioned around these parts any longer :(
YMMV 🤠
Viair 400P-Auto. Works great.
https://a.co/d/fpBKB7N
Viair 400P it's perfect, really impressive.
Strizzo
Bryan
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
I have a viar 450p, which has an automatic pressure shut off, so in theory it could be paired with a portable tank for a little more capacity/runtime.
On my last rig, i had one of the harbor freight high volume pumps for 7-8 years, and eventually converted it to an on board air setup and sold it with the truck. It would get through about three and a half tires before hitting the thermal shut off, but if I poured cold water on it while it ran it would fill all four without shutting off.
MyATV
Bill
ATL
Ford Bronco What Air Compressor do you use? 1690322383577
kodiakisland
Arkansas
Viair
CarGuy
New Jersey
2023 Ford Bronco
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Arb twin compressor with the Thors Lightning air system. I can do all 4 tires at once from 19 psi to 39 in about 5 minutes
What is that Oracle Lighting thing on your side mirror? 🧐 Doesn’t look like a light.
