What Air Compressor do you use?
goodgraf
Dallas
2022 Bronco Badlands
I use ARB twin onboard compressor with the Morrflate double setup for two tires at a time
Same here except with Morr quad connectors to allow inflate/deflate of all four at same time. About 5 mins to deflate and 15 to inflate.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
What air compressors do you all use out there to inflate/deflate tires?
I use ARB twin onboard engine-munted compressor with the Morrflate Quad setup for Four tires at a time
GreyBronco
Akron
Honda Element. 2 Civics and a Kawasaki ZRX1200R
It’s perfect!
Ford Bronco What Air Compressor do you use? IMG_0764
da_jokker
Jeep Wrangler JKUR
Smittybilt for me plus a self made 4 wheel hose setup for like $50.
Goes from 20psi to 35psi on all 4 tires in just a few minutes...just long enough for me to pop any rocks out of the treads :)
Smittybilt 2781 5.65 CFM... https://www.amazon.com/dp/B004K25GMG
Scott R Nelson
Meridian, ID
You must not have the Sasquatch Goodyear tires, because it would likely take hours to get every rock out of those treads. Every once in a while I try to get a few more little ones out of the spare, but give up on the idea before getting very far.
da_jokker
Jeep Wrangler JKUR
I do have the stock Sas tires...I keep one of those plastic trim tools in my glove box and about 30-45 seconds per tire while airing up, I can pop 99% of the rocks out.
I only do it for the poor guy behind me when I get back on the road :)
Jpargo
Plymouth
Toyota 4 Runner
Viair 400P it's perfect, really impressive.
Ford Bronco What Air Compressor do you use? 8256D85C-0CFA-4473-B2E9-8B7210C3014F
LCW
Twin Cities, MN
2019 4R TRD ORP, 2023 Bronco 2dr Badlands (gone)
Who makes a good underhood bracket mount for the ARB Twin?
Aman
Aman
Northern NJ
CyberOrangeBadlands
Joe
Long Island, NY
‘22 Bronco
Morrflate TenSix with the 4 hose + gauge.
Air down to 18 psi in under 2 minutes.
Air back up to 40 psi in under 8 minutes.
All 4 tires at once.
Beastly & highly recommend
cashe3
Charles
Atlanta
Hyundai Santa Fe
Have the Viair as well. So far I haven't needed to air down. So can't say I've actually "used" it.
