Water Fording
jorgem31
Jorge
Tampa
This Jeopardy? What was the question?
Headsong
jorgem31
Jorge
Tampa
I thought only the Everglades model had the breather tubes.
cowman
cowman
texas
ford
If it floats a boat use it instead of your Bronco..
DrXtoph
DrXtoph
Christoph
Miami FL
2022 F-150 XLT Texas Edition now, 2022 Badsquatch
They say it has breather tubes and give a greater fording depth in the marketing material, whereas it seems not to be publicly mentioned for other models.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
The breathers mentioned by Bronco team in OP’s post are for the front and rear differentials. A snorkel is what is on the Everglades. Basically all the Broncos have a max fording depth of 33”. Not sure on Everglades being it has a snorkel and all.
KABQ
Aaron
Albuquerque, NM
I feel like there are two previous messages that are essential if this is going to be helpful...
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Breather tubes, air intake & alternator locations are all different situations.
Breather tubes can be easily extended. I still don’t have my eff’n’ 2day reservation but “Back in the day” I extended the breather tube on my Tacoma’s rear differential. Took me about five minutes & cost me less than ten bucks with shipping.
Air intake can be augmented via a snork…but they’re really more helpful with dust.
Alternator…well I guess we’re just boned on that one.
da_jokker
Jeep Wrangler JKUR
And don't forget your transmission has a breather as well. Hopefully that is also high.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I have a lot of experience with water fording. I can tell you that the alternator issue, in my experience and observation is much less of an issue if you follow a common sense approach. 1. Do not exceed 33" of standing water. 2. Do not charge through the water, forcing water into the alternator or other sensitive areas under the hood (like the fuse panel). The picture below was taken with 18 other Broncos, in and out of water all day. At another event, we had 2 alternator issues, from Broncos charging through much shallower water at high speeds. It looked cool, but was definitely a high potential for problems. Other models may have better physical locations for the alternator (Jeep?) but I have seen a wide variety of electrical failure from charging through water, regardless of Brand or model. Nice to know about the breather tubes, I have been under my Bronco a fair amount, never took time to look for tubes.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Thanks for your comments. Anytime I’ve seen vehicles have water issues on the trail (non Bronco because unicorn) it’s been caused by IMPO poor technique via excessive speed and no bow wake. Plus let’s be honest the big splash thing is admittedly fun, it does not fall into the “Tread Lightly” ethos. Flame me all you like but it’s true. As avid offroad enthusiasts we have a responsibility to Tread Lightly and set a good example for responsible offroad recreation. End soap box, please carry on and return to previous rational discussion on breather tubes. 😎
