Water Fording
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
Has anyone here actually relocated the differential breathers?
That image says they are higher then the fording depth so we ashould be good.
But does anyone know how far above?
Think its worth moving them even higher incase you go an inch or so over the depth?
Deleted User 5719102
Who's
On a Lake
22 2dr
I'm pretty sure that anything above 3ft on a stock non lifted vehicle you start to experience vehicle floating.
Rootdog
Rob
Maine
Ram 2500
Is this too much? Didn’t think about the transmission?
Ford Bronco Water Fording D648CB41-0C5D-477D-A3EA-F308A2FBDAA0
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
That’s only about 18” should be fine not even touching the transmission yet
da_jokker
Jeep Wrangler JKUR
I'm sure it's on the board somewhere...but have we discovered where the top of the tubes are actually located for diffs, trans, and t-case?
flip
Phil
IN
www.ruxerparts.com
Fords
Here are the vent locations and as you can see, the trans/transfer case aren't very high. You could extend these up to the highest point in your engine compartment (we did this with mine vehicles that had problems with canister vents getting plugged up from running in the mud 24/7) but you will probably have issues with other things trying to go deeper. Water ingestion at the air cleaner flapper valve would be the big one, not to mention electrical connectors.
Ford Bronco Water Fording 1682513501189
Ford Bronco Water Fording 1682513713176
Ford Bronco Water Fording 1682513557425
Ford Bronco Water Fording 1682513594281
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Fact, seals are designed to hold fluid in. They are a one way flapper valve that tend to keep most of the water out. If you want to dunk your bronco you should be changing your fluids fairly often.
People focus to much on the vents, the vents become an issue when you stop and as components cool the suck in air or water. If in motion not really a big deal unless they are funneling water in.
Need to look at the EVAP setup next.
Big thing that's also not talked about is oil and grease displacement. All the tensioners and idlers on the front of the motor get splashed it helps work the grease out of the bearings. Same goes for any part rotating in a wet environment.
