Wastegate actuator loose/rattling. Anyone else have this issue?
EazyCheezy
2022 Ford Bronco Black Diamond
See video attached, but my 2022 2.3L has had this awful wastegate actuator rattle that can be heard in the cabin. If you’ve had this issue, do you have a fix? Any suggestions are appreciated because it’s such an irritating noise that happens every time the turbo kicks in.
I’d have an audio clip in-cabin but phones just don’t pick it up. Dealer says there’s nothing wrong, even after a ride along.
Clearly everything is fine. :rolleyes:
JJHTX
JJ
Houston, TX
2023 Ford Bronco
Mine doesn’t rattle like that, but it does make an annoying squealing noise. I’ve gone back and forth with dealership about it, and they initially kept telling me the same thing (nothing wrong and “we can’t replicate” bs). I felt compelled to be persistent about it (and a separate brake click issue) and escalated it beyond the service reps, until finally management agreed to replace the part. My truck is still at the dealership, unfortunately. Good luck on a fix for your issue.
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
So is this what rattles on most that sounds like a diesel under acceleration?
EazyCheezy
EazyCheezy
Sorry you’re dealing with the same issue. I’m trying to avoid the dealer as I’ve already been in 5 times (3 times for transmission & 2 times for my tailgate). Hopefully I can figure it out.
EazyCheezy
EazyCheezy
Yeah the sound is very annoying. No performance loss. I’ve just never driven a turbo car that has that rattle from the engine bay.
Fishwrinkle
Yeah me neither at it is very annoying especially when it’s cold out and under acceleration. I might look into seeing if I can turn a brass bushing, but haven’t looked that deep into it.
Fishwrinkle
Wrong forum, there bud?
bradcd
Brad
Indiana
Saab 9-3
Ya @raptorusmaximus's post is off topic but I did come to say try some grease. A thick grease like Lucas Oil red pushed in there could add some cushion. Do you think that arm pin is backing out?
EazyCheezy
EazyCheezy
Interesting. I’ll definitely look into Lucas Red. Can’t say for certain on the arm pin. I have, however, considered buying a new wastegate assembly from Ford or somewhere else and installing it myself at this point. 🙃
Fortydegnorth
Kettering Ohio
2022 Big Bend 4dr, 2023 Big Bend 2dr
We have 2 Broncos with 2.3 engines. Both have the wastgate squeak, but not a rattle that I’ve noticed. My 2023 squeak is much louder than my wife’s 2022. It’s mostly at idle and on a cold start. I don’t worry about it, but it is a weird noise.
Fishwrinkle
Grease will just melt off and definitely won’t help the rattle
Bigguyry2000
Ryan
Southern California
2021 Black Diamond
Mine has that also. I’m not worried about it til it breaks. The weirder thing is that at wide open mid to upper RPM I noticed I was getting wastegate pop like I was at the strip doing a launch control or 2 step. Only noticed after the procal tuner I just installed.
Have you noticed anything like that?
TXBronco1313
Yep mine makes the same noise which can be heard in the cabin when on idle or when slowly reversing. I noticed it days after I picked up my Bronco and took it back right away. Dealer had it for a whole week even got in contact with Ford and they told them to leave it as is for now. They even had me test drive 2 other 2.3s they had on the lot and all had the same noise. I can share a video of the cabin noise if anyone wants to compare their noise to mine but I believe we're all in the same boat
TXBronco1313
Mine isn't as much of a pop it's mostly rattling but yeah two days after I picked up my Bronco I took it right back to the dealership and they said it's normal
