Using a motor oil additive on 2.3L
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
Is anyone using a motor oil additive? My auto shop is recommending BG MOA. It gets good reviews for start/stop engines and turbochargers. It’s about $20 per oil change but carries a warranty.
I'm very much inclined, with a fairly new vehicle, to assume that between the manufacturer of the vehicle, and the manufactures of the oil which the vehicle's manufacturer recommends, that they know better what is good for the vehicle than any aftermarket additive manufacturer.
Now if we're talking about an old vehicle with a lot of wear, or one that is in some way being modified significantly outside the parameters of how it was originally engineered, then that may be a different matter.
Happy
Jerry
Missouri
CJ5, Wagoneer
STP is the racers edge
Ford Bronco Using a motor oil additive on 2.3L noise 2
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
What’s the purpose of the oil additive? Anti-foaming, extreme pressure, detergency?
I would not ads at the beginning of an oil change cycle. It seems like something that would extend the lube life.
I believe The owners manual specifically says they do not recommend the usage of oil additives. If using this product, I would not allow the dealer to do it, as to avoid appearing on the vehicle’s history.
Willub
Billy
Massachusetts
I’ve been using TriboTEX in my 2.3L EcoBoost and honestly, I’d choose it over BG MOA any day. It’s more than just an additive—it’s nanotech that actually restores wear surfaces. With start/stop and a turbo, I wanted something that reduces friction on cold starts, and TriboTEX has done a solid job. Smoother idle and less turbo whine under load. Not knocking BG MOA, but I trust the science behind TriboTEX more.
It magically muffles noise from the compressor wheel? Sounds almost unbelievable. SOLD!
