FTBronco9
F-150
I have around 1600 miles on my Big Bend 2.7. I decided to change the oil ASAP after my 1000-mile breakin. We have been camping, and this is the first chance I've gotten.
This video from another thread is a good reference:
I had trouble getting a filter...you can't just walk in to O'Reilly and ask for a 2021 Bronco filter. I got the part # from Ford and O'Reilly had them, but not OEM. But Wal-Mart had Motorcraft, and had one left. But question for those who know: why does the new one not have the black caps? Is this normal?
Anyway...I removed the skid plate-factory BB plastic one-using a 15mm socket to take out 6 bolts. My 15yo handled socket duties.
Confession: I haven't changed my own oil in years, so I've never used the plastic plugs. It was easy to take off (a quarter turn), and they weren't joking about it coming out quickly.
I also have never seen the top-of-engine filters, so I watched the video to find it. I didn't have a set of large sockets with me camping, so I had to use Vise-grips to get the housing off. No trouble.
I didn't install the new filter because of my questions about the caps, but I changed the rings. As in the video, I cut the small one with a razor knife to get it off. Getting the new one on there required some patience to be sure.
All that was left to do was reinsert the plug, rebolt the skid plate, and pour in 7 quarts of Mobil 1 synthetic. Checked for leaks and all is good.
A follow-up question: does the Bronco not have an oil pressure readout?
Did you say that your skid plate is plastic??!!
88to21bronco
88to21bronco
Tennessee
2017 Nissan Titan XD
Yup. Standard on BB. Going to upgrade as soon as I can sneak it past, um, get the ok from the wife. 😂
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
As difficult as it is to take off the small o-ring and put a new one on; makes you wonder if you're local Jiffy Lube even bothers changing it.
They use O ring hooks, Get some in your tool box.
da_jokker
Jeep Wrangler JKUR
Why do manufacturers even do this instead of just sticking with spin on filters?
crashmtb
North of nowhere
Focus RS, TD5 Defender
a crescent wrench or a socket work even better than a strap wrench. the strap wrench is great for the steel smooth spin on filters, but much more difficult to uses than a medium sized crescent wrench. when reinstalling the filter housing i recommend hand tight plus a quarter turn..
knipex pliers wrench. Goodbye vice grips. Goodbye crescent wrench.
or just carry the 4-6 common socket/wrench and torx bit sizes needed to do everything on most modern vehicles. 😬
crashmtb
North of nowhere
It‘s cheaper to produce a cartridge filter, and there is much less waste. A spin on filter uses a decent chunk of steel. With a cartridge filter, you‘re not replacing the housing often.
Cartridge filters can also be easily inspected for particulates.
they’re not really much harder to deal with than canister filters.
da_jokker
Jeep Wrangler JKUR
Did we establishe the Mobil 1 met the specs or no? That threat was hard to keep up with.
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
i will go out on a limb and speculate you never were a professional mechanic. the proper tools mean being able to do a repair or maintenance properly. when you tear up fasteners and and housings by using slip joint pliers or vise grips you are not a good mechanic. slip joint pliers, vise grips, oxy acetylene, hammers, and chisels are all last resorts for performing routine maintenance.... but WHT it's your car... i always took pride in my work.
dgorsett
colorado
F250, Mustang, Explorer
A recent video (Canadian guy) w/ A51 4d 2.3, you could see the filter from inside the engine compartment, looked getable. Ranger oil change videos show loosening plastic fender liner. Either way doesn't look bad. My sons Taco uses cartridge, o rings et all, I like the canister type like the 2.3, fewer points of failure.
BTW the video of the 2.3 engine compartment looked much better than the 2.7. More open and you could actually see and identify engine parts, looked workable.
crashmtb
North of nowhere
You didn’t read my post, or quoted the wrong one. I was saying vice grips and the likes are the wrong tool., and to carry the right ones.
I’ve seen professional mechanics misuse tools more often than you imply they do, so I’m not sure what that has to do with anything.
I was suggesting replacing vice grips or slip joint pliers with adjustable parallel jaw pliers. these:
brilliant tool.
69 Mach I
Sean
'15 F-150, '87 Mustang
Word of caution buying filters from Walmart, always check the filter to make sure it is what you are buying. I've seen it a few times where people will swap the cheapest filter in the Mobile 1 box. Cheap price to sell your soul for :sneaky:
True story.....once bought a filter from Walmart, got home and opened box, and it had a used filter in it!
2.3BigBend
PA
Work Beater
Heard the filter on the 2.3 is an absolute bitch to get to. Part of the reason I also went with the 2.7.
On the Ranger it was reported by several publications that the wheel had to be pulled, but that was false monkey see monkey do reporting. There is a flap with 3 push pins you remove. Then there was a "funnel" built in that worked remarkably well at channeling the oil. No where near an absolute bitch, about average to get to.
I actually noticed on build and price that it shows the filter on the side just like the Ranger. I can't confirm this tho?
I thought this too until I owned a Jeep with it. I have since owned two Ford 2.7's with the cartridge filter. No mess, easy to get to and (most important to me) you can see the filter element before and after your oil change. Some spin on's are easier to change, but a lot are harder and messier. What's not to love?
