URGENT - HELP NEEDED - STUCK WHEEL LOCKS
ks8780
Matt
Kansas
A bunch of Fords
I agree with Lifeliberty.
It looks like you broke a 3/8ths drive 3 inch extension. 3/8 drive is not gonna do what you are wanting to do. It's just not heavy enough. Upgrade everything to 1/2 inch drive and you will be fine. Including torque wrench if you want to use one. Also get a 1/2 inch drive breaker bar to remove your lugnuts instead of the torque wrench.
bigblackbronco
bigblackbronco
theodore
la quinta
2024 ford bronco big bend sasquatch
I ended up getting an upgraded 1/2 in torque wrench , 1/2 in breaker bar , and 1/2 to 3/4 plus a 1/2 to 7/8 deep well socket to fit the lug nuts and locking nuts which are inconveniently sized differently . Should be equipped to tighten and alternatively remove the nuts and locking nuts
SierraBronco
You still need a DCF961!
Don’t forget your antiseize. Though that then brings up another topic for internet arguments regarding how much the lubrication changes your applied torque and how much you should reduce your settings. And definitely don’t accidentally grab loctite instead of antiseize when doping your lugs. Wifey accidentally did that yesterday 🤣😬 Luckily she caught it and all was remedied. We could also argue about why everything is written as foot pounds instead of pounds foot.
SeptuagenerianSasquatch
Randy
Massachusetts
Have you reached out to AdvancedWheelLocks? Here's their phone contact:
Call or Text:
Toll Free: 1-833-295-6257
Local: 1-219-323-2067
9-5 Central time.
Have your identification and the number on your lock set handy when you do.
bigblackbronco
bigblackbronco
theodore
la quinta
Call or Text:
9-5 Central time.
I called and asked for an adapter about 2 weeks ago and never heard back. I found a remedy thanks to helpful advice from the forum. Leaving first thing in the AM so I’m on a time crunch
I have that socket set and it’s a rock star. My lug nut adapter uses the 19mm
The extensions are on my Christmas list
Some stuff at HF I wouldn’t trust beyond one use, but others are solid for life
bassist
Northern VA
2024 Bronco Badlands w/Sasquatch Package
Here’s a vote against antiseize.
The torque specs are for dry, and you will not get things torqued properly with antiseize on them.
KABQ
Aaron
Albuquerque, NM
If I just stumbled across that in a drawer I would think it’s set to 76.5
Disclaimer - I’m not a mechanic
I actually am a mechanic, and I agree that's set to 76.5.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
You need a breaker bar. harbor freight, Home Depot etc has them.
