UGH! MIC Top cracking
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Once the MIC tops have been around a few years and warranties are not covering them any longer the delamination will open up the core to water. Leaks will be inevitable because these tops are fabricated from corrugated cardboard and you know what happens to cardboard once it gets wet.
I would not consider honeycomb aramid paper "corrugated cardboard". It's much more rigid, and water resistant. I'm guessing even a cracked top will go many many years without any kind of degradation due to weather.
Dave2020GT
El Segundo, CA
2024 BMW M2 G87 6spd MT 2025 Ford Bronco
That was my feeling, it's used heavily in the aeronautical world
DALOLA
Retired
Ohio 🇺🇸
Yeah, it will be really interesting to see how these cracked tops hold up over the years. I'm guessing the concern is way overblown.
contented
Karl
Central Fl
BMW M2 Competition
You caused me to go looking for honeycomb aramid paper. Found this https://www.aramidcloth.com/aramid-honeycomb/ and much more. It seems aramid honeycomb is used in many applications. Very informative.
J-Lugster
Ancaster, Ontario
2024 Ford Bronco Wildtrak 4Dr Oxford White
Is it possible to replace the MIC tops with the painted tops? My BL is being built in a few weeks and its too late to change the order.
As long as it is not built yet, I would think Ford should be able to tweak the order.
I would even ask your dealer if the order tweak is not possible if they could just re-order you a new one because you don't want the MIC top because you've learned about all of the issues with it. Issues that continue into 2025.
tock13
Tony
WA State
That was interesting, kind of puts to rest the common “wet cardboard” comments I read here about what these MIC tops are made of. Reading the applications and properties of aramid it seems Ford really did try to make something good but the manufacturer just couldn’t pull off correctly…or at least consistently.
Dave2020GT
El Segundo, CA
My dealer told me it was too late to change the order.
TLO
Canada
youtube.com
2 door
Let's hope they do a little better job in 2026
You could put in a new order and wait...?
Dave2020GT
El Segundo, CA
My lease is up on my Bronco Sport BL. They can only extend it 90 days. Im looking forward to the 2025.
Jfman
jean
Canada
Accord
MIC is just plastic that is colores thru and thru correct?
What is the new top made from ?
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
J-Lugster
Ancaster, Ontario
No it is not coloured through and through. Coating is just on the top.
Pulled this from a Google search:
The Webasto-supplied Molded-In-Color (MIC) hardtop for the Ford Bronco is made of a composite material that primarily uses a paper honeycomb core covered by a mixture of polyurethane and reinforcing fibers. The exterior is covered with a grained, thermoformed, weatherproof film.
