Tow Mode? Normal or Sport?
NVCowboy
William
Henderson, NV
Maiden Voyage with the cargo trailer. What mode are people using? I'm guessing either normal or sport?
NVCowboy
William
Henderson, NV
2.7 auto. 4d. Squatch. 6x12 Cargo Conversion.
frdfan
Greg
LaVista Nebraska
22 BB Sasquatch HPRM
Since there is no "tow-haul" mode, except on the Braptor, I would use Normal. Sport mode will automatically turn on 4A--why risk burning up a transfer case.
Benzo
Ben
Bay Area CA
too many to list
I use sport mode when I tow and I push the 2 wheel button. I like the difference in shift points as well as the throttle response with 'sport' over 'normal' when leaving from a stop.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I've only ever towed in normal but I think I'll try this next time.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Go into the menu on the instrument cluster and there is a tow mode option there.
This is to tow your bronco, not tow WITH your Bronco.
NVCowboy
William
Henderson, NV
I've been playing with sport, and thought this might be the case. We'll see.
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
What is this mythical sport mode I keep hearing of? Does it need to be added via Forscan?
Benzo
Ben
Bay Area CA
too many to list
Yes. Forscan is required to enable this mode. There are many YouTube videos out there that show how it is done. The forscan thread on 6G has a spreadsheet showing what needs to be changed using the OBDC adapter and Windows Forscan software.
grayshadow
Charles
Humble, Texas
grayshadow
Charles
Humble, Texas
Badlands does not have “sport” mode. You received the “Baja” mode instead.
NVCowboy
William
Henderson, NV
Sport for the win. Normal you know it's back there. Sport. Trailer? What Trailer?
JohnnyBronco
Pennsylania
X4
Your transfer case will not burn up from towing in 4A. Sport mode is preferable in my book for towing AZ it locks out the upper two overdrive which is what tow mode on every other vehicle accomplishes. You do not want to tow in OD. Many other vehicles that are AWD with no selection of 2WD tow just fine with greater payload.
Since selecting Sport Mode automatically selects 4A (it can then be shut off) then go ahead and tow all day long in anything but 4H or 4 L.
