Total Noob - Winch Install
xxNomad74
Damon
Nashville, TN
2025 Bronco
I bought my first Bronco in July (Heritage Edition): and I’ve made a few insignificant changes - grab bars, thumb screws for topper, floor mats - but I purchased the Ford Performance Warn winch kit and installed it today. I have the capable bumper and had to make some cuts to fit the brackets, but all things considered, it turned out fairly well. Took about 5 hours, and I’m pleased with the result. I don’t consider myself a mechanical person, so if I can do it, anybody could do it.
Ford Bronco Total Noob - Winch Install IMG_8071
Ford Bronco Total Noob - Winch Install IMG_8070
Caldoh
Cal
NH
Ford Bronco
Nice job. Congrats on the install.
swamp2
Great job. Also nice of you to share the experience to help get others who may be concerned about this job, getting it over the line, as a DIYer.
NC_Oak
2024 4 door 2.3 sasq
I notice the wire loom on those eliminated the white tape / banding that mine came with. I painted it as it was annoying to see the white band on the loom.
Nice job on install. If you're a noob to winch use, I highly recommend playing with it in a controlled environment. hook it up to a tree and pull the bronco. get used to how it works. pulleys, shackles, all the things.
Bschurr
NY
Good advice there along with some recovery training. Additionally, @xxNomad74 you need to tension the synthetic line
xxNomad74
xxNomad74
Damon
Nashville, TN
2025 Bronco
Thanks for all the feedback. When i did the Off-Roadeo in Maryville, TN, they had a quick lesson on recovery techniques. I have a tree saver strap, some D-Ring/pulley combos, and soft shackles. I definitely need to try it out just to get the experience. Glad to have a group of folks that can share their knowledge. Thanks again.
BigFootie
Wisconsin
Looks great on the Heritage. I like this implementation better than the hidden winch version. Did you do the FDRS modifications to the RCM module as recommended by the instructions?
xxNomad74
xxNomad74
Damon
Nashville, TN
2025 Bronco
I did not. Being new to all of this, what are the possible ramifications of not doing it?
BigFootie
Wisconsin
I’m not sure which was why I was asking. It’s the restraint control module and affects crash detection and seat belt stuff.
I have heard it modifies the airbag deployment parameters - but I think it’s not critical. I suspect it’s just one of those CYA things Ford does since it’s an official Ford item and they have to prove to NHTSA on crash stuff - none of the aftermarket guys do the same or even recommend it. And there is no apparent difference with or without the FDRS update
