Torx PLUS not common Torx!
dcg2
Don
PA
Honda CR-V
Just an FYI for anyone planning on working on their bronco with the Torx bolts on it.
They are a mix of Torx and Torx PLUS. Torx PLUS is not the same as Torx even though they are the same size.
Take off your beauty rings with a T45 Torx bit and you risk stripping them at worst and frustration with the bit "camming out" at best.
Wheel trim rings are regular Torx. Bronco bolts are Torx+
I talked to TWO different auto parts stores. The individuals I talked to had never heard of Torx PLUS and assured me that Torx bits would work fine.
$24 to me is a cheap investment to make sure you have the right tools for the job: https://smile.amazon.com/Neiko-10086A-Tp8-Steel-Socket/dp/B004UC9WJE/
Courtesy of @VoltageDrop a very reasonably priced set Made in USA:
https://smile.amazon.com/gp/aw/d/B005OH0MES
Apologize if this posts belongs somewhere else but I feel like it should be more prominently displayed if it is somewhere else.
Zeke013
Oregon
They didn't give us the right head to pull the "Bronco" bolts . . . .
Amazing.
kodiakisland
Arkansas
I believe it’s been mentioned quite a bit, but will continue to be an issue.
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
They are Torx PLUS. Torx PLUS is not the same as Torx even though they are the same size.
Agree had to go to harbor freight to get the right size torque bit to install bull bar
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Oh great it's like JIS screws on Japanese motorcycles. Most people use Phillips and you get a lot of mangled screws.
wetdog
Bruno
pacific coast
2019 jl
Oh boy I remember thesis ,taking the secondary butterflies out of my zx14 you had one chance at it and you had to heat the bit and hold it in there so the lock title melted.
Busterbronco1
Andy
2005 Mustang GT Premium and 1982 F100 Short Bed.
Thank you for this information!!!
